- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
MODULE mytype1
TYPE mytype
INTEGER, POINTER, DIMENSION(:) :: ptr
END TYPE mytype
CONTAINS
! rename a to b
SUBROUTINE rename(a, b)
IMPLICIT NONE
TYPE(mytype) :: a
TYPE(mytype) :: b
b%ptr => a%ptr
NULLIFY(a%ptr)
RETURN
END SUBROUTINE rename
END MODULE mytype1
PROGRAM test
USE mytype1
IMPLICIT NONE
TYPE(mytype) :: a, b
INTEGER :: i
! create a
ALLOCATE(a%ptr(100))
a%ptr = 1
CALL rename(a, b)
! then we can use b
DO i = 1, 100
b%ptr(i) = i
ENDDO
STOP
END PROGRAM
I have a large code doing the similar thing. And when I turn O3 on
with Intel Visual Fortran compiler 11.1.054. The code crashes and I am pretty
sure it is the 'rename' subroutine that causes the problem. But I did
not see anything wrong in it. Is there any danger in 'rename' which is
not so obvious?
Reply from Steve Lionel:
It is evident that you retyped in the code as you showed it here, as it
has several syntax errors. When I correct the syntax errors and build
it with /O3 and Intel Visual Fortran 11.1.054 (and 11.1.065), it runs fine.
I conclude, then, that the code you showed here is not representative of
your actual code. Paraphrases and uncompilable excerpts do not help in
getting your problem resolved. Please provide an actual test case.
My answer:
The problem is that the actual code is so large and propertery that I
am sure no one want to really look into it.
I add few print statements in my actual code at the beginning of
rename and after. Something like:
IMPLICIT NONE
TYPE(mytype) :: a
TYPE(mytype) :: b
print *, associated(a%ptr), associated(b%ptr), size(a%ptr), size(b
%ptr)
b%ptr => a%ptr
NULLIFY(a%ptr)
%ptr)
RETURN
And I saw the second print did not give me the expected output.
Although a%ptr is not associated, its size is not zero. (I guess it is
not specified in the Fortran reference.) This is tolerable. On the
other hand, b%ptr is associated but its size is not equal to the size
of a%ptr in the first print statement. It gave me 1! If I run the code
under Debug mode, everything is just fine.
I am sorry I am not able toprovide the actual code.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am also pretty frustrated because of the problem. I can not reproduce it in the testprogram too. I did the similar thing to 'rename' with 'copy(a,b) + delete(a)' in the actual code and the problem is gone. But it is really not necessary.
Actually in the real code, ptr is pointed to null() in the type definition.
The actual rename subroutine is also very simple. There is no way that I misunderstand the code.
My question is:
how possible the size of a pointer is not equal to the size of another which the pointer is just pointed to?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I doubt that the size is the issue. You are correct that if a pointer is not associated, its size is undefined. I think it is likely you are overwriting memory somewhere.
I'll be interested to see a test case that shows the problem.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The real type definition:
! Compressed Sparse Row format
TYPE CSR
INTEGER :: n ! number of rows
INTEGER :: m ! number of columns
INTEGER :: nnz ! number of non-zeros
INTEGER :: nnz_capacity ! capacity of non-zeros
INTEGER :: mcount ! memory count in bytes
REAL(RKD), DIMENSION(:), POINTER :: a =>null() ! (nnz_capacity) non-zeros
INTEGER, DIMENSION(:), POINTER :: ia =>null() ! (n+1) pointers to the beginning of each row of all non-zeros
INTEGER, DIMENSION(:), POINTER :: ja =>null() ! (nnz_capacity) column index of all non-zeros
END TYPE CSR
The real rename subroutine:
SUBROUTINE csr_rename(a, b)
IMPLICIT NONE
TYPE(CSR) :: a
TYPE(CSR) :: b
print *, a%n, a%m, a%nnz, a%nnz_capacity, associated(a%a), associated(a%ia), associated(a%ja), size(a%a), size(a%ja), size(a%ia)
print *, b%n, b%m, b%nnz, b%nnz_capacity, associated(b%a), associated(b%ia), associated(b%ja), size(b%a), size(b%ja), size(b%ia)
b%ia => a%ia
b%ja => a%ja
b%a => a%a
NULLIFY(a%ia, a%ja, a%a)
b%n = a%n
b%m = a%m
b%nnz = a%nnz
b%nnz_capacity = a%nnz_capacity
b%mcount = a%mcount
a%mcount = 0
RETURN
END SUBROUTINE csr_rename
And the output:
144 144 5216 5216 T T T 5216 5216 145
0 0 0 0 F F F 4192 4192 145
144 144 5216 5216 F F F 5216 5216 145
0 0 0 0T T T 1 1 1
The last three 1s do not make sense. The print statement happens just after the assignments. Overwriting memory does not explain this. If I use /check:all, the problem is gone.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
So on the compiler side, can you have any thoughts on how this possibly happens with the optimization so that the range for me to find the bug is limitted? If not, I will rewrite the rename subroutine with copy+delete operations.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I saw that Richard Maine and Jim Xia gave you some good general advice in the newsgroup.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
For the Runtime Error Checking, if I just turn 'check array and string bounds', then the error is gone.
The command line is:
/nologo /O3 /Qip /fpp /I"C:\works\tt\projects3D" /I"C:\Program Files\MPICH2\include" /gen-interfaces /Qsave /module:"Release\" /object:"Release\" /check:bounds /libs:static /threads /c /Qinline-factor=1000
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I suggest you open an issue with Intel Premier Support and attach the actual program.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
