29030 Discussions
Apparently no search in default paths for ifmodintr.lib
Michiel_V_
Dear forum users,
While working with Intel Parallel Studio XE 2016 integrated in Microsoft Visual Studio 2015 to work on a C++ program that uses a Fortan library, I came across the following linker error:
1>LINK : fatal error LNK1104: cannot open file 'ifmodintr.lib'
The library file does exist however and is located in C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.2.180\windows\compiler\lib\ia32_win
It seems that this default path is not being searched during linking. If I simply add the path to "Additional Library Directories" of the (C++) project at hand, the error dissappears, confirming my idea that it has to do with searching the default paths. In "Tools => Options => Intel Compilers and Tools" I found that ''IFortInstallDir" was expanding to the wrong path. I could correct this by selecting the proper compiler via "Selected compiler", but strangely this hasn't solved the LNK1104 error yet.
Any suggestions are welcome, best regards,
Michiel.
Steven_L_Intel1
See https://software.intel.com/en-us/articles/configuring-visual-studio-for-mixed-language-applications for instructions on how to configure C++ for linking to Fortran. None of the Fortran options have an effect on this.
Michiel_V_
Thank you very much Steve, this solved it indeed!
