Application Error
elf
I'm using CVF6.5a and I got the following error when I tried to execute a program. What does it mean? In fact, I've tried to run the same program under MSFPS4.0 which appeared to be okay. Please help. Thank you
The exception Array bounds exceeded.
(0xc000008c) occued in the application at location 0x00403352
james1
It is telling you that you used an array subscript that is not within the defined limit of the array being accessed, for example if you defined an array INTEGER A(10) and accessed A(11) or A(0), etc while the code is executing.
By default I believe CVF IDE has array bounds checking turned on. You can either turn it off (/check:nobounds) or change the code to only access array elements within the defined range. Usually the latter is preferable.
James
