29425 Discussions
Are !$OMP ATOMIC directives necessary in an !$OMP CRITICAL region?
OP1
New Contributor III
The following code snippet is located inside a !$OMP PARALLEL region. THIS_THREAD and LOCAL_FAILED_THREAD are private variables, FAILED_THREAD is a shared variable.
I am wondering if it is truly necessary to use the !$OMP ATOMIC directives inside the !$OMP CRITICAL region. The intent here is to guarantee memory consistency between what each local thread thinks FAILED_THREAD is; but maybe the mere fact that the access (read or write) to FAILED_THREAD is inside the !$OMP CRITICAL region is sufficient in itself to guarantee this?
    THIS_THREAD = OMP_GET_THREAD_NUM()
    !$OMP CRITICAL
    !$OMP ATOMIC READ
    LOCAL_FAILED_THREAD = FAILED_THREAD
    !$OMP END ATOMIC
    IF (LOCAL_FAILED_THREAD==-1) THEN
        LOCAL_FAILED_THREAD = THIS_THREAD
        !$OMP ATOMIC WRITE
        FAILED_THREAD = LOCAL_FAILED_THREAD
        !$OMP END ATOMIC
    END IF
    !$OMP END CRITICAL
    IF (THIS_THREAD==LOCAL_FAILED_THREAD) THEN
    ! Do some work here.
    END IF
jimdempseyatthecove
On Intel processors IA32 and Intel64 (but not necessarily IA64 and not necessarily some other processors) the above atomics may be unnecessary. A cleaner solution would be to use FLUSH
!$OMP CRITICAL
!$OMP FLUSH(FAILED_THREAD)
END IF
!$OMP END CRITICAL
END IF
Jim Dempsey
jimdempseyatthecove
Note, the code provided is indicative that FAILED_THREAD is read elsewhere. Where it is read may require !$OMP FLUSH(FAILED_THREAD) as well.
Jim Dempsey
IanH
Flush is implied at a number of locations, including the entry and exit of a critical region (OpenMP 4.5 p168).
If all reads and writes of FAILED_THREAD are within that critical construct then ATOMIC is not required.
OP1
New Contributor III
Thanks to all for the clarification!
jimdempseyatthecove
Depending on the rest of the code, it may or may not require more immediate notification than that at the end of the parallel region. This is a design consideration.
Jim Dempsey
