29386 Discussions
Assumed-size arguments in External procedures
David_Mccabe
I am currentlymoving a lot of code over to the intel fortran compiler.
In the existing code, there are a large number of calls to external procedures which use assumed-len or assumed-shape dummy arguments, but no interface is used. Here's an example:
program char_array
character(len=10),dimension(2) :: arg
arg(1)="hello"
arg(2)="world"
call test(arg)
end program char_array
subroutine test(arg)
character(len=*),dimension(:),intent(in) :: arg
write(*,*) arg(1)
write(*,*) arg(2)
read(*,*)
end subroutine test
I understand this is bad practice and an interface should be used, but adding interfaces orputting the procedures into moduleswould take too long.
My question is:
Is therea compiler option which wouldguarantee that the codewould compile and run without an error?
TimP
Assumed shape requires interface specification. Without that, the compiler should reject it.
Assumed size will be checked by the -gen-interfaces compiler option. This option leaves automatically generated interface blocks in the build directory.
As Tim suggests, /warn:interface will catch this (in most cases). This is on by default in a Debug configuration in a Visual Studio project. From the command line, add /warn:interface. Without the compiler being able to "see" the external routine, it has no idea that there is a problem.
C:\Projects>ifort /warn:interface t.f90
Intel Visual Fortran Compiler XE for applications running on IA-32, Version 12.1.1.258 Build 20111011
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
t.f90(11): warning #7978: Required interface for passing assumed shape array is
missing from original source [ARG]
call test(arg)
