Assumed type internal compiler error
faustino_de_sousa__j
Hi!
Code generates an internal compiler error:
C code:
#include <stdlib.h>
#include <stdio.h>
void ifb_echo(void*);
void ifb_echo(void *this){
  printf("pointer: %p\n", this);
  return;
Fortran code:
program ifb_p
  use, intrinsic :: iso_c_binding, only: c_null_ptr
  implicit none
  interface
    subroutine ifb_echo_aux(this) bind(c, name="ifb_echo")
      implicit none
      type(*), intent(in) :: this
    end subroutine ifb_echo_aux
  end interface
  call ifb_echo_aux(c_null_ptr)
  stop
end program ifb_p
using:
ifort (IFORT) 19.0.1.144 20181018
icc (ICC) 19.0.1.144 20181018
José Rui
Steve_Lionel
I can't reproduce an error using 19.0.5. What command line did you use?
Hi Steve,
Yes, I forgot to check the compiler options... :-(
It seems to boil down to:
-assume noprotect_constants
José Rui
Steve_Lionel
Yes - I can see that one now. If you have a license with support, I'd recommend that you report this to Intel using the orange "Bug Report" button on the main forum page.
Why are you using that option, though? Do you know what it does?
I was assuming that -assume=none was invoking more strict standard conformant behaviour...
Or at least there was a time it used to be so, or maybe I am just confused...
I assume I will have to read the documentation more carefully... ;-)
I have an hobbyist license I do not think it includes support.
Thank you very much.
José Rui
FortranFan
faustino de sousa, jose rui wrote:
I was assuming that -assume=none was invoking more strict standard conformant behaviour.....
Try -standard-semantics:
https://software.intel.com/en-us/fortran-compiler-developer-guide-and-reference-standard-semantics
Steve_Lionel
-standard-semantics changes compiler defaults that don't align with F03 and later. It doesn't, on its own, make anything "more strict". There are many -assume options you need enabled in order to match standard semantics.
