29386 Discussions
Attempting to invoke ifort from regular command line
awa5114
I am attempting to invoke ifort from the regular windows command prompt. I tried browsing to the Intel Fortran bin directory and running what batch files I found that looked appropriate. For this instance I ran:
compilervars.bat
compilervars_arch.bat
ifortvars.bat
vsshel2010vars_arch.bat
Then I browsed to my folder containing my source files and tried doing an operation that required use of the linker. This threw an error:
-out:test.exe
-subsystem:console
test.obj
module1.obj
module2.obj
LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
I'm not sure why it cannot open said file. Is there a batch file I omitted to run? I don't want to just blindly run every batch file I can get my hands on. Is it even possible to invoke ifort in the regular command prompt?
Arjen_Markus
Maybe you are overdoing it ;). I always use the Start menu and the item for Intel Fortran. It takes some searching, depending on the actual version of Intel Fortran you are using, but there ought to be an entry which brings up the command prompt. And I would think that ifortvars.bat is enough, perhaps with suitable parameters.
awa5114
I need to use the regular windows command prompt because I'm developing a batch script that will need to operate as a runner in a TeamCity project. I think the command line runner in TeamCity doesn't have ifort built in so using only the intel command prompt is out of question.
In light of the error I am showing what, in your opinion, are some suitable parameters?
Arjen_Markus
I tried this:
> "c:\program files (x86)\....\ifortvars.bat" intel64
> ifort someprogram.f90
and that worked as a charm.
Our set-up with Team City uses the Visual Studio solution to build the programs. That might be an alternative.
awa5114
Hi @Arjen Markus.
That worked for me also. It turns out I was omitting the intel 64 option. Thanks for the follow-up.
Arjen_Markus
Yes, I had the same problem - the definition of the menu items was not very easy to comprehend, but with a little experimentation the usage of the batch files was.
awa5114
I do have another question though. It appears that  clicking "run" on the Build Step: Command Line in Team City complains about "No enabled compatible agents for this build configuration. Please register a build agent or tweak build configuration requirements"
Under "Agent Requirements" I do see that the command line runner is set as "disconnected". Any ideas on this? Thanks
