29650 Discussions
Automatic pointer with generic interface fails to compile
Martin1
ifort from the oneAPI toolkit (ifort -V: Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.1 Build 20201112_000000 on Linux) does not compile the attached code, which should be valid. The reason seems to be that the compiler fails to resolve a call to a generic interface with an automatic pointer (argument has no pointer attribute but has a target attribute). Directly calling the routine compiles.
FortranFan
Prima facie, this looks like a bug to me also.
Please submit this as support request at Intel OSC if you're able to.  https://supporttickets.intel.com/?lang=en-US
Barbara_P_Intel
I filed another bug report for you, CMPLRIL0-33514. I'll post it here on the thread when it's fixed.
Martin1
Devorah_H_Intel
The fix will be available in the next oneAPI release.
