29607 Discussions
Automatic save of Bitmaps from plotted QuickWin Graphics
onkelhotte
New Contributor II
Hi there,
when I plot some kind of graphics in a QuickWin Window I can save that file manually as a bmp with file -> save. Is there a way to save that graphic automatical when its being plotted on the screen? I could catch that window with saveimage (x,y...) but I need a more general way to save that graphic.
Thanks in advance,
Markus
Jugoslav_Dujic
Valued Contributor II
I don't see what's wrong with SaveImage? Can you clarify?
Jugoslav
onkelhotte
New Contributor II
With saveimage I have to use different coordinates for every single image. With an automatic save I dont have to think about that...
Jugoslav_Dujic
Well, I'm affraid there's no simpler way -- but you can retrieve the bounding coordinates relatively easily as one of:
1) coordinates from your code, or
2) returned from GetViewport, or
3) returned from GetWindowConfig
depending on which is the most suitable.
Jugoslav
