Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
BIND(C,NAME="longliteral") causes ICE
Theodore_T_1
This code causes Internal Compiler Error with ifort 19.0.4.227.
I would like to be able to use longer character constants.
!                                           1         2         3
Integer Function f() Bind (C,Name='_23456789012345678901234567890&
&12345678901234567890123456789012345678901234567890123456789012345')
!         4         5         6         7         8         9
  f = 0
  Return
End Function f
Juergen_R_R
Valued Contributor I
An ICE is always a compiler error. Please report this to the Online Support team.
Theodore_T_1
I've done so, case #04197187
