29564 Discussions
BUG or SYNTAX ERROR? error #5082: Syntax error, found '::' when expecting one of: , : (/ ]
DataScientist
Valued Contributor I
ifort 2022 (linux WSL) cannot compile the following code snippet.
Is the compiler error correct? Is line continuation disallowed in this case?
integer, allocatable :: A(:)
A = [integer &
:: 0]
end
FortranFan
Considering the Fortran standard document,
  1. Re: "Is the compiler error correct?" - no.  Intel Fortran does not conform by failing to process the continued statement.
  2. Re: "Is line continuation disallowed in this case?" - no.  Per the standard, the shown continuation is allowed.
DataScientist
Here is an example run:
https://godbolt.org/z/rrcsE5TTf
FortranFan
FortranFan
A temporary workaround until a compiler resolution might be to move the double colon separator to the previous line:
   A = [ integer :: &
       & 0 ]
end
Barbara_P_Intel
Uh, oh! This one almost slipped by!
Thanks for reporting it. I filed the bug as CMPLRLLVM-43404.
DataScientist
Fantastic. Thank you for your meticulous attention to bug reports and surely not the least, for the great compilers.
Ron_Green
We have a fix in the pipeline for this bug.  The fix will appear in the 2024.2.0 ( Update 2).  This is roughly due end of June or in July 2024.
DataScientist
fantastic! Thank you.
