29565 Discussions
Better a select vs. Character or Integer?
Allamarein
I have to run a select to interpret a variable. Actually the select case is based on character(len=10) variable, but I could substitute that with an integer. If I did that, would I improve the speed of my code? Pratically speaking, dealing with character vars slows the code? Regards
My first advice is to use whichever makes the program easier to understand. If you have analyzed performance and found the SELECT to be a bottleneck, then changing to integer may help because the compiler can better optimize that. I wouldn't waste any time on this, however, unless it was demonstrated to be a problem.
Allamarein
In fact I preferred using character, because it allows to better understand the meaning. Using an integer as an identification code would require a table to browser each time to guess what the code does. I will follow your advice. Perhaps this is the last of my problem today. Thanks
