Browse for Folders
Brooks_Van_Horn
I've checked on several previous posts and the code they supplied to browse for folders but too many things have changed with IVF. In my 2016 Composer XE I don't have a file called extrawinty.f90 nor many other things. Some of the solutions lead you to a website that VIPRE says is very bad and the file no longer exists there. So, does anyone have a code segment and how to use it? This is the last section of code for my project.
Brooks
andrew_4619
it is in C:\Program Files (x86)\Intel\Composer XE\Samples\en_US\Fortran\win32.zip
andrew_4619
GetOpenFilename is a windows API tool the is an example of using is in the ifort sample programs
andrew_4619
Brooks_Van_Horn
Hi Andrew,
I've looked at that example and I use it in my project; however, I did find
GetSaveFileName which will serve my purpose.
Thsnkd much,
Brooks
PS, missed you the last few days.
Steven_L_Intel1
GetSaveFileName is used exactly the way GetOpenFileName is, just for a Save dialog.
andrew_4619
Has anyone got the newer  IfileDialog Interface working in Fortran, I had a quick look at it a couple of year ago and I recall a number of other forum members have looked at it and run away......
Paul_Curtis
Valued Contributor I
I will point out that, although deprecated, SHBrowseForFolder() works fine in Windows 10.
INTEGER                                 :: pidl
CALL COMInitialize (status)
buffer = folderPath
!    TYPE T_BROWSEINFO
!        SEQUENCE
!        INTEGER                        :: hwndOwner
!        INTEGER                        :: pidlRoot
!        INTEGER                        :: pszDisplayName
!        INTEGER                        :: lpszTitle
!        INTEGER                        :: ulFlags
!        INTEGER                        :: lpfn
!        INTEGER                        :: lParam
!        INTEGER                        :: iImage
!    END TYPE T_BROWSEINFO
bi%hwndOwner      = hwndParent
bi%pidlRoot       = NULL
bi%pszDisplayName = LOC(buffer)
bi%lpszTitle      = LOC(titleBuffer)
bi%ulFlags        = BIF_RETURNONLYFSDIRS
bi%lpfn           = NULL
bi%lParam         = 0
bi%iImage         = 0
!	SHBrowseForFolder returns an item identifier list.
pidl = SHBrowseForFolder (bi)
IF (pidl /= 0) THEN
	SELECT CASE (windows_version)
	!	Win95 and Win98
	CASE (VER_PLATFORM_WIN32_WINDOWS)
		! We need to ask the shell to decode the item identifier
		! list into a parseable name. First, retrieve an IShellFolder
		! COM interface handle to the desktop folder.
		rval2 = SHGetDesktopFolder(LOC(IShellFolder_desktop))
		IF (rval2 == NOERROR) THEN
			! Use the GetDisplayNameOf method to convert the item
			! identifier list into a string. The SHGDN_FORPARSING flag
			! indicates we want the parseable path, not the general-
			! purpose display label.
			rstring%uType = STRRET_CSTR
			rval2 = IShellFolder_GetDisplayNameOf (IShellFolder_desktop,
												   pidl,
												   SHGDN_FORPARSING,
												   LOC(rstring)
				folderPath = rstring%cStr
				CmnDlgChooseFolder = .TRUE.
			END IF
		END IF
	!	WinNT, Win2K, WinXP
	CASE DEFAULT           !(VER_PLATFORM_WIN32_NT)
		CmnDlgChooseFolder = SHGetPathFromIDList (pidl, folderPath)
	END SELECT
    CALL CoTaskMemFree (pidl)
END IF
CALL COMUnInitialize ()
andrew_4619
Thanks for commenting Paul. I know the older (deprecated) file API's work OK in W10 and are unlikely to stop working any time soon. I was interested if anyone has implemented the newer (not deprecated) IFileDialog API's?
Paul_Curtis
Moi aussi.
