Bug in Intel OpenMP?
Tue_B_
I believe the following demonstrates a bug in intels openMP parallelization
    program Console1
    use omp_lib
    implicit none
    integer :: pn
    integer :: n,j,NCPUS,i
    NCPUS=8
    call omp_set_num_threads(NCPUS)
    !!$OMP PARALLEL DEFAULT(PRIVATE) SHARED(NCpus) REDUCTION(+:J)
    !J=0
    !!$OMP DO
    !  do i=1,NCpus
    !    J=J+1
    !  end do
    !!$OMP END DO
    !!$OMP END PARALLEL
    call omp_set_num_threads(1)       !This is here because there used to be a problem in intel Fortran openMP, where the thread pool had to be set to 1 before defining a new threadpool.
    pn=7
    !$OMP PARALLEL DEFAULT(NONE) SHARED(pn),private(i)
      !$OMP MASTER
        do i=1,pn
         !$OMP TASK firstprivate(i)
           call sleep(1)
           print*,'Task ',i
         !$OMP END TASK
        end do
        !$OMP TASKWAIT
      !$OMP END MASTER
    !$OMP END PARALLEL
    end program Console1
With the first parallel region commented out, (as it is right now in the above example), the second parallel region runs the tasks in parallel as expected, if however the first region is uncommented the second region does not run in parallel.
I have compiled the above with Visual Fortran Compiler XE 15.0.2.179 [Intel(R) 64].
Can anyone shed some light on this issue (or perhaps just confirm it in the first place), and give me a workaround if any such exist?
Kevin_D_Intel
Now I’m seeing what you are. Initially the compiler version indicated was 15.0.2.179 compiler. The more recent posts show Composer XE 2015.4.221 and when run using the OpenMP library from this release, I get the same results as you.
The problematic libiomp5md.dll is version 5.0.2015.324 (from Composer XE 2015.4.221).
A version that appears to work is an earlier version 5.0.2014.1201 (from Composer XE 2015.2.179).
It appears this OpenMP library defect was also fixed in the subsequent Composer XE 2015.5.280 release which has a newer libiomp5md.dll, version 5.0.2015.609.
I don’t know how you prefer to deal with this. The 15.0 compiler is older but I presume maybe you have a reason for wanting to use that. It appears you have at least both the 15.0.2.179 and 15.0.4.221 installed on your system so maybe it is easier to revert to the earlier 15.0.2.179 for now, or perhaps you have the later 15.0.5.280 installed and can use that.
Whichever versions you have installed, under VS IDE you can select the compiler used via Tools > Options > Intel Compilers and Tools > Visual Fortran > Compilers and set the Selected Compiler pull down for Win32 and/or x64.
jimdempseyatthecove
You have minor bug in program. Revised program below.
program Console1
use omp_lib
implicit none
integer :: pn
NCPUS=8
J = 0 ! *** initialize before reduction clause
! **** J=0  ! move to before parallel region if done once (as implied by above reduction)
!$OMP DO
  do i=1,NCpus
    J=J+1
  end do
!$OMP END DO
!$OMP END PARALLEL
pn=8
  !$OMP MASTER
    do i=1,pn
       call sleep(1)
       print*,'Task ',i, omp_get_thread_num() ! verify done in parallel
     !$OMP END TASK
    end do
    !$OMP TASKWAIT
  !$OMP END MASTER
!$OMP END PARALLEL
With pn=7 (note omp thread 4 not used)
 Task            4           7
 Task            3           5
 Task            5           3
 Task            1           1
 Task            7           0
 Task            2           2
 Task            6           6
Press any key to continue . . .
with pn=8
 Task            2           1
 Task            3           5
 Task            4           6
 Task            7           7
 Task            8           0
 Task            1           3
 Task            5           2
 Task            6           4
In your original code, you initialized J by all threads inside the parallel region. The do loop may have ** completed ** by one thread of the team prior to a different thread initializing J. In which case the reduction (or partial reduction) may get clobbered.
Your second parallel region, as written, may have shown all (7) task being run, but it had no indication of parallelization. For this I added the OpenMP thread (team member) number.
Edit: You could potentially have J=0 in both places, but since the first do loop is executed once, it would be redundant to do so.
Jim Dempsey
Tue_B_
Running the altered code that Jim provided, I get exactly the same issue as I had before...
The output I get is:
 Task            8           0
 Task            7           0
 Task            6           0
 Task            5           0
 Task            4           0
 Task            3           0
 Task            2           0
 Task            1           0
Not only is this the output I get, but the code also remains stuck after printing the last task (it never exits the parallel region again, which is incidently the same problem kept encountering in this thread https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/734424)
Note that this bug seems to be task specific. If I instead of the task syntax, insert a do loop the second parallel region runs just fine.
program Console1
use omp_lib
implicit none
integer :: pn
NCPUS=8
!$OMP DO
  do i=1,NCpus
    J=J+1
  end do
!$OMP END DO
!$OMP END PARALLEL
pn=8
!$omp parallel default(none) shared(pn),private(i)
  !$omp do schedule(dynamic)
    do i=1,pn
      call sleep(1)
      print*,'task ',i, omp_get_thread_num() ! verify done in parallel
    end do
  !$OMP END DO
!$omp end parallel
OUTPUT:
 task            4           6
 task            2           7
 task            6           2
 task            1           0
 task            7           3
 task            5           5
 task            8           1
 task            3           4
andrew_4619
You are are using  XE 15.0.2.179 [Intel(R) 64] i would expect Jim is running a later version?????
Kevin_D_Intel
Using Jim's variant, I am seeing results consist with him with the 15.0.2.179 compiler.
with pn=8
C:\ u735131>  ifort /Qopenmp u735131.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.2.179 Build 20150121
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 12.00.21005.1
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:u735131.exe
-subsystem:console
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
u735131.obj
C:\ u735131>  .\u735131.exe
 Task            1           4
 Task            7           3
 Task            8           0
 Task            4           7
 Task            3           1
 Task            6           2
 Task            5           5
 Task            2           6
jimdempseyatthecove
Tue,
All your tasks (second region) are run by OpenMP thread (team member) number 0.
This indicates on of several things:
a) you compiled without -qopenmp (or equivalent)
b) you compiled with -qopenmp and linked with the openmp stubs library
c) you compiled with -qopenmp and linked with the openmp parallel library and have an OpenMP related environment variable set to force 1 thread (or non-parallel)
d) you are running on a system that is providing only one logical processor
Jim Dempsey
Tue_B_
Considering I do not change compiler settings between the runs make where I do have parallelizations and the runs I do not, I do not see how any of those options are realistic. As far as I can tell the issue comes from:
where the second call of omp_set_num_threads is somehow not respected, and instead 1 thread is thenenforced in the task region. From what I'm seeing this looks like a clear cut bug in the compiler, though why I'm the only one seeing it I'm not sure about, I'll try to do some more tests and verify all the compiler flags tomorrow.
jimdempseyatthecove
Check your library path. This may be a case of your executable loading a DLL from an older version of Fortran. Kevin ran the test program using the same version of the compiler as you reported you use. I assume the DLL that ran with Kevin's test was from the same version of the compiler he used. This is one additional variable.
Jim Dempsey
Tue_B_
Jim Dempsey
This is something I'm not entirely sure how to do, I've been programming for quite a few years at this point, but I have never really been the one setting up our system, so I'm actually not sure how to find the library paths used when compiling, I checked the logfile that was created when building the test program:
Compiling with Intel(R) Visual Fortran Compiler XE 15.0.4.221 [Intel(R) 64]...
ifort /nologo /debug:full /Od /Qopenmp /warn:interfaces /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc110.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qvc11 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\\bin\amd64" "Z:\Projects\2014_AirTech4Water\Software\ftn\Old_examples\OMP_TASK_v4\Console1\Console1.f90"
Linking...
Link /OUT:"x64\Debug\Console1.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"x64\Debug\Console1.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"Z:\Projects\2014_AirTech4Water\Software\ftn\Old_examples\OMP_TASK_v4\Console1\x64\Debug\Console1.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"Z:\Projects\2014_AirTech4Water\Software\ftn\Old_examples\OMP_TASK_v4\Console1\x64\Debug\Console1.lib" "x64\Debug\module.obj" "x64\Debug\Console1.obj"
Link: executing 'link'
Embedding manifest...
mt.exe /nologo /outputresource:"Z:\Projects\2014_AirTech4Water\Software\ftn\Old_examples\OMP_TASK_v4\Console1\x64\Debug\Console1.exe;#1" /manifest "x64\Debug\Console1.exe.intermediate.manifest"
Console1 - 0 error(s), 0 warning(s)
I'm guessing there is some default paths that it searches for the needed dlls, but I'm not exactly sure how to see which paths it is, or which dll's it searches for.
andrew_4619
Put "show progress" ( /VERBOSE  ) on the linker options.
andrew_4619
/VERBOSE:LIB is less information but probably all you need.
Tue_B_
By using Verbose I get what is shown below. Now I'm not entirely sure how to actually figure out which dlls are loaded based on what I'm reading, but as far as I can see I'm guessing the most relevant file for openMP is the libiomp5md.dll, which I think it finds in C:\Program Files (x86)\Intel\Composer XE 2015.4.221\redist\intel64\compiler. The version I have of this file everywhere I look appear to be 5.0.2015.324
I'm guessing there is a newer version somewhere I should try
1>------ Build started: Project: Console1, Configuration: Debug x64 ------
1>Linking...
1>Starting pass 1
1>Processed /DEFAULTLIB:ifconsol
1>Processed /DEFAULTLIB:libifcoremdd
1>Processed /DEFAULTLIB:libifportmd
1>Processed /DEFAULTLIB:libiomp5md
1>Processed /DEFAULTLIB:libmmdd
1>Processed /DEFAULTLIB:MSVCRTD
1>Processed /DEFAULTLIB:libirc
1>Processed /DEFAULTLIB:svml_dispmd
1>Processed /DEFAULTLIB:OLDNAMES
1>Processed /DEFAULTLIB:ifmodintr.lib
1>Searching libraries
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\ifconsol.lib:
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\libifcoremdd.lib:
1>      Found for_set_reentrancy
1>        Referenced in Console1.obj
1>        Loaded libifcoremdd.lib(libifcoremdd.dll)
1>      Found for_write_seq_lis
1>      Found for_write_seq_lis_xmit
1>      Found __IMPORT_DESCRIPTOR_libifcoremdd
1>        Referenced in libifcoremdd.lib(libifcoremdd.dll)
1>      Found __NULL_IMPORT_DESCRIPTOR
1>      Found libifcoremdd_NULL_THUNK_DATA
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\libifportmd.lib:
1>      Found SLEEP
1>        Loaded libifportmd.lib(libifportMD.dll)
1>      Found __IMPORT_DESCRIPTOR_libifportMD
1>        Referenced in libifportmd.lib(libifportMD.dll)
1>      Found libifportMD_NULL_THUNK_DATA
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\libiomp5md.lib:
1>      Found __kmpc_begin
1>        Loaded libiomp5md.lib(libiomp5md.dll)
1>      Found omp_set_num_threads
1>      Found __kmpc_global_thread_num
1>      Found __kmpc_ok_to_fork
1>      Found __kmpc_serialized_parallel
1>      Found __kmpc_end_serialized_parallel
1>      Found __kmpc_fork_call
1>      Found __kmpc_end
1>      Found omp_get_thread_num
1>      Found __kmpc_master
1>      Found __kmpc_end_master
1>      Found __kmpc_omp_task_alloc
1>      Found __kmpc_omp_taskwait
1>      Found __kmpc_reduce_nowait
1>      Found __kmpc_atomic_fixed4_add
1>      Found __kmpc_end_reduce_nowait
1>      Found __kmpc_for_static_init_4
1>      Found __kmpc_for_static_fini
1>      Found __kmpc_barrier
1>      Found __IMPORT_DESCRIPTOR_libiomp5md
1>        Referenced in libiomp5md.lib(libiomp5md.dll)
1>      Found libiomp5md_NULL_THUNK_DATA
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\libmmdd.lib:
1>    Searching C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\lib\amd64\MSVCRTD.lib:
1>      Found _RTC_CheckStackVars
1>        Referenced in module.obj
1>        Loaded MSVCRTD.lib(stack.obj)
1>      Found mainCRTStartup
1>        Loaded MSVCRTD.lib(crtexe.obj)
1>      Found "void __cdecl _RTC_StackFailure(void *,char const *)" (?_RTC_StackFailure@@YAXPEAXPEBD@Z)
1>        Referenced in MSVCRTD.lib(stack.obj)
1>        Loaded MSVCRTD.lib(error.obj)
1>      Found __CxxSetUnhandledExceptionFilter
1>        Referenced in MSVCRTD.lib(crtexe.obj)
1>        Loaded MSVCRTD.lib(unhandld.obj)
1>      Found _XcptFilter
1>        Loaded MSVCRTD.lib(MSVCR110D.dll)
1>      Found _amsg_exit
1>      Found _setargv
1>        Loaded MSVCRTD.lib(dllargv.obj)
1>      Found __imp___getmainargs
1>      Found __imp___set_app_type
1>      Found __imp__CrtDbgReportW
1>      Found __imp__CrtSetCheckCount
1>      Found _IsNonwritableInCurrentImage
1>        Loaded MSVCRTD.lib(pesect.obj)
1>      Found __imp_exit
1>      Found __imp__exit
1>      Found __imp__cexit
1>      Found __security_init_cookie
1>        Loaded MSVCRTD.lib(gs_support.obj)
1>      Found _matherr
1>        Loaded MSVCRTD.lib(merr.obj)
1>      Found atexit
1>        Loaded MSVCRTD.lib(atonexit.obj)
1>      Found _RTC_Initialize
1>        Loaded MSVCRTD.lib(initsect.obj)
1>      Found __imp__configthreadlocale
1>      Found __imp___setusermatherr
1>      Found _initterm_e
1>      Found _initterm
1>      Found __C_specific_handler
1>        Referenced in MSVCRTD.lib(error.obj)
1>        Referenced in MSVCRTD.lib(pesect.obj)
1>        Referenced in MSVCRTD.lib(atonexit.obj)
1>      Found __globallocalestatus
1>        Loaded MSVCRTD.lib(xthdloc.obj)
1>      Found _commode
1>        Loaded MSVCRTD.lib(xncommod.obj)
1>      Found _dowildcard
1>        Loaded MSVCRTD.lib(wildcard.obj)
1>      Found _newmode
1>        Loaded MSVCRTD.lib(_newmode.obj)
1>      Found __imp___initenv
1>      Found __native_startup_state
1>        Loaded MSVCRTD.lib(natstart.obj)
1>      Found _fmode
1>        Loaded MSVCRTD.lib(xtxtmode.obj)
1>      Found __imp__fmode
1>      Found __imp__commode
1>      Found __xi_a
1>        Loaded MSVCRTD.lib(cinitexe.obj)
1>Processed /DEFAULTLIB:kernel32.lib
1> Processed /DISALLOWLIB:libcmt.lib
1> Processed /DISALLOWLIB:libcmtd.lib
1> Processed /DISALLOWLIB:msvcrt.lib
1>      Found "int (__cdecl*__cdecl _RTC_GetErrorFunc(void const *))(int,char const *,int,char const *,char const *,...)" (?_RTC_GetErrorFunc@@YAP6AHHPEBDH00ZZPEBX@Z)
1>        Loaded MSVCRTD.lib(userapi.obj)
1>      Found "int __cdecl _RTC_GetSrcLine(unsigned char *,wchar_t *,unsigned long,int *,wchar_t *,unsigned long)" (?_RTC_GetSrcLine@@YAHPEAEPEA_WKPEAH1K@Z)
1>        Loaded MSVCRTD.lib(pdblkup.obj)
1>      Found __GSHandlerCheck
1>        Referenced in MSVCRTD.lib(pdblkup.obj)
1>        Loaded MSVCRTD.lib(gshandler.obj)
1>      Found __security_check_cookie
1>        Referenced in MSVCRTD.lib(gshandler.obj)
1>        Loaded MSVCRTD.lib(amdsecgs.obj)
1>      Found __security_cookie
1>        Referenced in MSVCRTD.lib(gs_support.obj)
1>        Referenced in MSVCRTD.lib(amdsecgs.obj)
1>        Loaded MSVCRTD.lib(gs_cookie.obj)
1>      Found "void __cdecl terminate(void)" (?terminate@@YAXXZ)
1>        Referenced in MSVCRTD.lib(unhandld.obj)
1>      Found __crtSetUnhandledExceptionFilter
1>      Found __IMPORT_DESCRIPTOR_MSVCR110D
1>        Referenced in MSVCRTD.lib(MSVCR110D.dll)
1>      Found _lock
1>      Found _unlock
1>      Found __imp__calloc_dbg
1>      Found __dllonexit
1>      Found __imp__onexit
1>      Found wcscpy_s
1>      Found _wmakepath_s
1>      Found _wsplitpath_s
1>      Found __report_gsfailure
1>        Loaded MSVCRTD.lib(gs_report.obj)
1>      Found MSVCR110D_NULL_THUNK_DATA
1>      Found __crt_debugger_hook
1>        Referenced in MSVCRTD.lib(gs_report.obj)
1>      Found __crtUnhandledException
1>      Found __crtTerminateProcess
1>      Found __crtCaptureCurrentContext
1>      Found __crtCapturePreviousContext
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\libirc.lib:
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\svml_dispmd.lib:
1>    Searching C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\lib\amd64\OLDNAMES.lib:
1>    Searching C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\ifmodintr.lib:
1>    Searching C:\Program Files (x86)\Windows Kits\8.0\lib\win8\um\x64\kernel32.lib:
1>      Found __imp_EncodePointer
1>        Loaded kernel32.lib(KERNEL32.dll)
1>      Found __imp_IsDebuggerPresent
1>      Found __imp_RaiseException
1>      Found __imp_GetLastError
1>      Found __imp_GetProcAddress
1>      Found __imp_LoadLibraryExW
1>      Found __imp_lstrlenA
1>      Found __imp_LoadLibraryW
1>      Found __imp_MultiByteToWideChar
1>      Found __imp_WideCharToMultiByte
1>      Found __imp_QueryPerformanceCounter
1>      Found __imp_GetCurrentProcessId
1>      Found __imp_GetCurrentThreadId
1>      Found __imp_GetSystemTimeAsFileTime
1>      Found __imp_DecodePointer
1>      Found __imp_HeapAlloc
1>      Found __imp_HeapFree
1>      Found __imp_GetProcessHeap
1>      Found __imp_VirtualQuery
1>      Found __imp_FreeLibrary
1>      Found __imp_GetModuleFileNameW
1>      Found __imp_GetModuleHandleW
1>      Found IsProcessorFeaturePresent
1>      Found __IMPORT_DESCRIPTOR_KERNEL32
1>        Referenced in kernel32.lib(KERNEL32.dll)
1>      Found KERNEL32_NULL_THUNK_DATA
1>      Found main
1>        Loaded libifcoremdd.lib(for_main.obj)
1>      Found for_rtl_init_
1>        Referenced in libifcoremdd.lib(for_main.obj)
1>      Found for_rtl_finish_
1>      Found for__nt_signal_handler
1>      Found signal
1>      Found __intel_new_feature_proc_init
1>        Loaded libirc.lib(new_proc_init.obj)
1>      Found __intel_cpu_feature_indicator
1>        Referenced in libirc.lib(new_proc_init.obj)
1>        Loaded libirc.lib(cpu_feature_disp.obj)
1>      Found __libirc_get_msg
1>        Loaded libirc.lib(irc_msg_support.obj)
1>Processed /DEFAULTLIB:uuid.lib
1>      Found __intel_proc_init_ftzdazule
1>        Loaded libirc.lib(proc_init_utils.obj)
1>      Found __imp_FormatMessageA
1>        Referenced in libirc.lib(irc_msg_support.obj)
1>      Found __imp_LoadLibraryA
1>      Found __imp_GetThreadLocale
1>    Searching C:\Program Files (x86)\Windows Kits\8.0\lib\win8\um\x64\uuid.lib:
1>      Found strlen
1>      Found strncat
1>      Found sprintf
1>      Found vsprintf
1>      Found strncpy
1>      Found printf
1>      Found memset
1>        Referenced in libirc.lib(proc_init_utils.obj)
1>Finished searching libraries
1>Finished pass 1
1>
1>      Found _load_config_used
1>        Loaded MSVCRTD.lib(loadcfg.obj)
1>Unused libraries:
1>  C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\ifconsol.lib
1>  C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\libmmdd.lib
1>  C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\svml_dispmd.lib
1>  C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC\lib\amd64\OLDNAMES.lib
1>  C:\Program Files (x86)\Intel\Composer XE 2015.4.221\compiler\lib\Intel64\ifmodintr.lib
1>  C:\Program Files (x86)\Windows Kits\8.0\lib\win8\um\x64\uuid.lib
1>Starting pass 2
1>     Console1.obj
1>     module.obj
1>     libifcoremdd.lib(for_main.obj)
1>     libifcoremdd.lib(libifcoremdd.dll)
1>     libifportmd.lib(libifportMD.dll)
1>     libiomp5md.lib(libiomp5md.dll)
1>     MSVCRTD.lib(unhandld.obj)
1>     MSVCRTD.lib(atonexit.obj)
1>     MSVCRTD.lib(cinitexe.obj)
1>     MSVCRTD.lib(crtexe.obj)
1>     MSVCRTD.lib(dllargv.obj)
1>     MSVCRTD.lib(gs_cookie.obj)
1>     MSVCRTD.lib(gs_report.obj)
1>     MSVCRTD.lib(gs_support.obj)
1>     MSVCRTD.lib(merr.obj)
1>     MSVCRTD.lib(natstart.obj)
1>     MSVCRTD.lib(pesect.obj)
1>     MSVCRTD.lib(wildcard.obj)
1>     MSVCRTD.lib(amdsecgs.obj)
1>     MSVCRTD.lib(loadcfg.obj)
1>     MSVCRTD.lib(gshandler.obj)
1>     MSVCRTD.lib(_newmode.obj)
1>     MSVCRTD.lib(xncommod.obj)
1>     MSVCRTD.lib(xtxtmode.obj)
1>     MSVCRTD.lib(xthdloc.obj)
1>     MSVCRTD.lib(userapi.obj)
1>     MSVCRTD.lib(stack.obj)
1>     MSVCRTD.lib(pdblkup.obj)
1>     MSVCRTD.lib(initsect.obj)
1>     MSVCRTD.lib(error.obj)
1>     MSVCRTD.lib(MSVCR110D.dll)
1>     libirc.lib(irc_msg_support.obj)
1>     libirc.lib(cpu_feature_disp.obj)
1>     libirc.lib(proc_init_utils.obj)
1>     libirc.lib(new_proc_init.obj)
1>     kernel32.lib(KERNEL32.dll)
1>Finished pass 2
1>Embedding manifest...
1>
1>Build log written to  "file://Z:\Projects\2014_AirTech4Water\Software\ftn\Old_examples\OMP_TASK_v4\Console1\x64\Debug\BuildLog.htm"
1>Console1 - 0 error(s), 0 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
Kevin_D_Intel
jimdempseyatthecove
Kevin, Tue,
You can also create a folder named something like ompFix and copy the working libiomp5md.dll into there, and then add the path to that folder to PATH (in front of any Intel folders). You must remember to undo this when you update your compiler version with a fixed version of libiomp5md.dll.
An alternative method would be to copy the working dll into the same folder as you place the execuitable (or into the current directory used at time of run). See: https://msdn.microsoft.com/en-us/library/7d83bc18.aspx for DLL search path information.
Jim Dempsey
Tue_B_
Thank you guys for helping me out, I really appreciate it!
