Bug in pfxint8get() in ifort
James_B_14
Compiler Versions: 15.0.2, 17.0.0
OS: RHEL 6.8
Kernel: 2.6.32-642.4.2 64-bit
Compile lines:
Works fine:    ifort -O3 -o test1 mopen.F
Gives wierd results: ifort -check all -o test2 mopen.F
The test1 and test2 executables produce two completely different results.
The following code produces this error:
        program htemp
        use ifposix
        implicit none
        integer(8) islen
        character*16 myfile
        integer(4) lename,ipxflag,ipxmode,ipxfd,ipxerr,ipxlen4
        integer(4) :: jstat_h
        integer(8) :: ipxlen
! open the signal
        myfile="mopen.F"
        write(6,*)  'opening ',myfile
        ipxflag=IPXFCONST('O_RDONLY')
        ipxmode=0
        lename=len_trim(myfile)
        call PXFOPEN(myfile,lename,ipxflag,ipxmode,ipxfd,ipxerr)
        write(6,*)  'PXFOPEN returned ',ipxfd
        if(ipxerr.gt.0) stop
        call pxfstructcreate('stat',jstat_h,ipxerr) ! create stat structure
        call pxffstat(ipxfd,jstat_h,ipxerr)
        call pxfint8get(jstat_h,'st_size',ipxlen,ipxerr)
        write(6,*)  'pxfint8get returned st_size ',ipxlen
        call pxfintget(jstat_h,'st_size',ipxlen4,ipxerr)
        write(6,*)  'pxfintget  returned st_size ',ipxlen4
        call pxfstat(myfile,lename,jstat_h,ipxerr)
        INQUIRE(file=myfile,size=islen)
        write(6,*)  'INQUIRE    returned         ',islen
        call pxfstructfree(jstat_h,ipxerr)
        contains
        end program htemp
mecej4
I can see the problem on Windows, as well (versions 2015, 2016 and 2017). I think that the real problem is that pxfint8get() is returning the INT8 argument with only the lower 32 bits set. If I add
             ipxlen=transfer(Z'BAADF00DDAABD00F',ipxlen)
before the call to pxfint8get(), the returned value is -4995072473058769535, or Z'BAADF00D00000581', instead of the correct value, 1409 or Z'0000000000000581'.
In effect, the upper 32 bits are undefined, so the value returned in those bits can be anything, and can be affected by changing compiler options.
Check if your "weird" results, when expressed in hex, are correct in the lower 8 nybbles.
Xiaoping_D_Intel
Thanks for reporting the error. I have reproduced it and opened a bug report for it. The bug ID is DPD200588804.
Xiaoping Duan
Intel Customer Support
