The following code produces a wrong result using ifort (IFORT) 11.1 20100203 (that is 11.1.084):
As one can easily see, bla and inn should have the same results. Yet, for inn I get 0-nn as a result. Here is the output of the program:
I am working on a 64bit Mac OS X 10.6.5 with an Intel Core i5. Unfortunately, I have no access to newer versions of ifort and so I cannot check whether it was fixed in the more recent releases. I did try it with 11.1.067 and there the result is correct.
[fortran]PROGRAM test
IMPLICIT NONE
REAL :: nn(6), inn(25), bla(24)
nn = 0.
nn(1) = 1.
nn(4) = 1.
!identity - nn^transpose
inn(1) = 1. - nn(1)
inn(2) = 1. - nn(2)
inn(3) = 1. - nn(3)
inn(4) = 0. - nn(4)
inn(5) = 0. - nn(5)
inn(6) = 0. - nn(6)
bla(1) = 1. - nn(1)
bla(2) = 1. - nn(2)
bla(3) = 1. - nn(3)
bla(4) = -nn(4)
bla(5) = -nn(5)
bla(6) = -nn(6)
PRINT '(A,F8.2,F8.2,F8.2)', 'nn = ', nn(1), nn(6), nn(5)
PRINT '(A,F8.2,F8.2)', ' ', nn(2), nn(4)
PRINT '(A,F8.2)', ' ', nn(3)
PRINT '(A,F8.2,F8.2,F8.2)', 'inn = ', inn(1), inn(6), inn(5)
PRINT '(A,F8.2,F8.2)', ' ', inn(2), inn(4)
PRINT '(A,F8.2)', ' ', inn(3)
PRINT '(A,F8.2,F8.2,F8.2)', 'bla = ', bla(1), bla(6), bla(5)
PRINT '(A,F8.2,F8.2)', ' ', bla(2), bla(4)
PRINT '(A,F8.2)', ' ', bla(3)
END
[/fortran] As one can easily see, bla and inn should have the same results. Yet, for inn I get 0-nn as a result. Here is the output of the program:
[bash]nn = 1.00 0.00 0.00
0.00 1.00
0.00
inn = -1.00 0.00 0.00
0.00 -1.00
0.00
bla = 0.00 0.00 0.00
1.00 -1.00
1.00[/bash] I am working on a 64bit Mac OS X 10.6.5 with an Intel Core i5. Unfortunately, I have no access to newer versions of ifort and so I cannot check whether it was fixed in the more recent releases. I did try it with 11.1.067 and there the result is correct.
I don't have a Macintosh, so this is a guess. See if this post is applicable and try the workaround of adding -use_asm as an option to take care of the problem.
This does not appear related to the earlier issue mecej4 cited.It also reproduces with our latest release and at all opt-levels.I will report this to our Developers and update when I learn more.
Thank you very much for your answer. I did not know about this incompatibility.
I have Xcode 3.2.3 and when I tried it with ifort 11.1.067 I did it on a machine with Xcode 3.2.1. On my own machine it did not help to switch to 11.1.067. Your suggestion to add "-use_asm" on the other hand did fix the issue for me. Until I can get my hands on the latest ifort-Version (I need to go through the university to get it), I will try to use that workaround...
PS: I had tried it with no optimizations ("-O0") earlier and that "fixed" the issue too...
on my macbook pro with ifort 11.1.084 I get wrong results with optimization set at -O1 -O2 etc.
I get correct results at -O0
hope this helps yout as a temporary workaround
After some additional testing, I found that I misspoke earlier. The issue is reproducible using 11.1.084 and it does appear related to the issue mecej4 cited. My apologies. It does not reproduce at -O0.
As per the cited article, you may also work-around this issue with 11.1.084 and adding: -use-asm
The issue is also fixed in the 11.1.089 update.
Sorry again for the earlier misinformation.
I was actually curious on what would happen in C++ for it (using icc (ICC) 11.1 20100203) and here we go. The following C++ code also gets wrong results:
[cpp]#includeCorrect result (generated with g++ or icc -O0 ... or icc -use_asm ...):int main() { double nn[6], inn[6], bla[6]; nn[0] = 1.0; nn[1] = 0.0; nn[2] = 0.0; nn[3] = 1.0; nn[4] = 0.0; nn[5] = 0.0; inn[0] = 1.0 - nn[0]; inn[1] = 1.0 - nn[1]; inn[2] = 1.0 - nn[2]; inn[3] = 0.0 - nn[3]; inn[4] = 0.0 - nn[4]; inn[5] = 0.0 - nn[5]; bla[0] = 1.0 - nn[0]; bla[1] = 1.0 - nn[1]; bla[2] = 1.0 - nn[2]; bla[3] = -nn[3]; bla[4] = -nn[4]; bla[5] = -nn[5]; std::cout << "n =t" << nn[0] << "t" << nn[5] << "t" << nn[4] << std::endl; std::cout << " t t" << nn[1] << "t" << nn[3] << std::endl; std::cout << " t t t" << nn[2] << std::endl; std::cout << "bla =t" << bla[0] << "t" << bla[5] << "t" << bla[4] << std::endl; std::cout << " t t" << bla[1] << "t" << bla[3] << std::endl; std::cout << " t t t" << bla[2] << std::endl; std::cout << "inn =t" << inn[0] << "t" << inn[5] << "t" << inn[4] << std::endl; std::cout << " t t" << inn[1] << "t" << inn[3] << std::endl; std::cout << " t t t" << inn[2] << std::endl; return 0; } [/cpp]
[bash]n = 1 0 0
0 1
0
bla = 0 0 0
1 -1
1
inn = 0 0 0
1 -1
1
[/bash] Wrong result (generated with icc):[bash]n = 1 0 0
0 1
0
bla = 0 0 0
1 -1
1
inn = 0 0 0
0 0
0
[/bash] - Mark as New
Yes. The root-cause involves the GNU linker (ld) handling of a specific form of symbol namewhich both our C/C++ and Fortran compilers may use.The resultwas both C/C++ and Fortran programs can be affected. Our compilers (starting with 11.1.089) were changed to avoid using the problematic form of symbol name.
I also confirmed this C++ case fails with C++ 11.1.084 and is fixed C++ 11.1.089 update.
