Dear everyone!
Hi, sorry for opening a topic if there is sth related to this one!
the problem is that: when I want to setup the System Environment using : "Visual Fortran Build Environment for applications running on IA-32"
I face this Error:
Unable to find Microsoft Visual C++ 7.1 or Higher!
I already installed Microsoft Visual C++ 2010 express to solve the problem and also I've installed Microsoft Visual C++ redistribution of 2008 and 2010 in PC!
Now I don't know what to do? what should I do?
Best
链接已复制
Dear Steve;
Thanks for your reply
Here is the picture for my Fortran Compiler Ver, and the error!
I really don't know! how to solve the problem!
I'm working on my thesis! I decided to work by Matlab, the problem on Matlab was an error which had said:
Error: Could not find the compiler "ifort" on the DOS path.
Use mex -setup to configure your environment properly.
G:\MATLAB\R2011A\BIN\MEX.PL: Error: Unable to locate compiler.
Using mex-setup didn't help! it was not possible to find the right compiler because I didn't have Intel Fortran Compiler on the PC! then I got Intel Fortran Compiler for that! Now I faced this problem when I want to change my system environment!
Even If you can tell me how I can solve the main problem, that's enough! waiting for your suggestion! Thanks a lot!
Do you have Microsoft Visual Studio 2003 or 2005 installed? 2010 won't work. Depending on what your license is, or how you installed, the Fortran install may or may not have added VS2005 Premier Partner Edition. If it didn't, you need to uninstall Fortran and install "Intel® Visual Fortran for IA-32 and Intel® 64 (with Microsoft Visual Studio 2005 Premier Partner Edition*)"
Dear Steve
Thanks for your hint! I don't have VS2003 or 5! so I decided to uninstall Fortran and install what you gave me thanks for that!
Is there sth else to do after installing the software you gave me to solve my main problem? would the PC recognize the compiler ifort for my calculations?
Best
If you are comfortable working from the command line, here is an "unsupported" but reliable way of building a MEX from Fortran source, which is easy enough to try, and may save you a lot of wasted effort expended in installing different versions of Intel Fortran and/or Matlab. I have Matlab 2007b (32-bit) installed, and I have tested the steps below with the 32-bit compilers IFort 7.0, IFort 13.1, IFort 14.0 and IFort 15.0-beta.
1. Open a 32-bit IFort command window. Inside that command window, run these batch commands (please insert the correct directory paths for your installation) to set the MEX-compatible environment.
set MLDIR=c:\Math\ML2007b\extern set INCLUDE=%INCLUDE%;%MLDIR%\include set LIB=%LIB%;%MLDIR%\lib\win32\microsoft set LINK=libmx.lib libmex.lib /export:MEXFUNCTION
2. To build a MEX file from the example provided with Matlab, copy yprimef.F and yprimefg.F to a working directory. Within that directory, issue the command
ifort /LD /fpp yprimef.F yprimefg.F
(Note: With version 7 of Intel Fortran, use "ifl" instead of "ifort")
3. Test the MEX file within Matlab.
4. If you wish, modify the source files and rebuild the MEX file as noted in Step-2.
Dear Friends;
I've got a new problem! I decided to get Visual Basic 2008 for my problem, Cause Intel Fortran 11.1 matches with VB 2008 for MATLAB!
I've downloaded the VB 2008 from microsoft.com but I get this error! And I really can't solve it! any clue will be appreciated!
Let me tell you that it is not an update version! If you think it is! so please give me a link to download a full but no problem a trail one!
You didn't download VB, you downloaded Service Pack 1 for VS2008, and whatever version of VS2008 you have on the system, if any, isn't compatible with that. This has nothing to do with Intel Fortran.
As David says, if you have VS2008 Express (which will work with Intel Visual Fortran only in command line mode), the Service Pack won't work with it. If you have a regular version of Visual Studio, you can add in VB by doing a "Change/Modify" in Add/Remove Programs (or Programs and Features on Win7 and 8.) You cannot download VB to add to Visual Studio.
Thanks for your replies guys!
Sorry; I made a mistake in my last post! I didn't mean VB 2008, I meant VS 2008!
I've downloaded VS 2008 and as you said VS 2008 Pro SP1! and I just decided to ask from you expert guys for clue to solve the problem!
Do you guys know a link for downloading trail version of regular VS 2008 from microsoft.com?
I really don't know which one is regular for VS 2008? what should I do? what should I install on my PC to have VS 2008 there? I don't have any version of VS in my PC, so what should I have in my PC to install this SP1?
I really confused!
Thanks for your reply!
If the Visual Studio 2008 Pro 90-day trial is no longer available, you might follow Steve's advice above and use the PPE provided with ifort installer. Apparently, only the 2010, 2012, and 2013 VS pro trials are available, so you would need a more recent ifort to follow that route.
