Build program with data from file
gib
New Contributor II
I am planning to create a program that will use a big array of constant data when it executes. The obvious thing to do is read the data from a file, but I'm wondering if there is a way to read the data in during the compilation and store it with the executable code. Obviously this could be achieved by a DATA statement, but for a big multidimensional array it is a bit cumbersome. I'm pretty sure the answer is that there is no alternative to the DATA statement, but maybe there is something I don't know about.
TimP
Quoting - gib
Put the DATA statement in an INCLUDE file?
gib
New Contributor II
Quoting - tim18
Quoting - gib
It's generating the DATA statement that I was hoping to avoid. A vain hope, obviously, but it isn't a big deal anyway.
IanH
Quoting - gib
If you are only running on Windows then a user defined resource may suit. The data can be pulled from a file at (resource) compile time, which is then bound into the executable or DLL (as per other resources such as dialog templates or strings). At run time you then use Windows API functions such as FindResource and LoadResource, possibly in combination with the C_F_POINTER procedure from ISO_C_BINDING, to make the data available to the program.
I have used this approach to bind a default configuration file into an executable.
The online documentation for the resource compiler (rc.exe) has more information.
IanH
gib
New Contributor II
Quoting - IanH
IanH
Ah, thanks Ian, that's the sort of thing I was looking for. Unfortunately I'd like to run this on other platforms besides Windows. It seems I'll have to write a little program to create the DATA statement.
jimdempseyatthecove
You could potentially use Excel to generate the data satatments
1.2 3.4 5.6 ...
9.8 7.6 5.4 ...
Insertcolumns at left and at right
'DATA Array('1 ':' 10 ') /' 1.2 3.4 5.6 ... '/'
'DATA Array('+R-1C+10 ':' +R-1C+10 ') /' 1.2 3.4 5.6 ... '/'
Or write a program to convert the data to an includ file.
Use the Excel method for a once only situation
Use the program method should you want to create multiple tables or tweek the table later.
Jim Dempsey
