29429 Discussions
Building a level-one equation solver from a level-zero equation solver
NotThatItMatters
I have a function class which takes some parameters as arguments and returns functional values.  This is something along the lines of
TYPE, EXTENDS(FuncBase) :: FuncBunch
    INTEGER, PRIVATE :: Nn
    INTEGER, DIMENSION(:), ALLOCATABLE, PRIVATE :: Data_Set
    ! 0 = first constraint, 1 = second constraint
    INTEGER, PRIVATE :: DataConstraint
    ! 0 = single bunch constraint, 1 = two bunch constraints
    INTEGER, PRIVATE :: IConstraint ! Constraint_Type
CONTAINS
    PROCEDURE :: Func => Func_Bunch
    PROCEDURE :: FuncV => FuncV_Bunch
    PROCEDURE :: FDJAC => FDJAC_Bunch
    PROCEDURE :: MaximumStep => MaximumStep_Bunch
    PROCEDURE, ...
END TYPE FuncBunch
The idea here is that there are scalar functions Func and vector functions FuncV both of which need to be solved (values == 0.0).  I have some basic root solvers in a separate class to solve the single-variable and multi-variable cases.  The solver itself lies in a module with solvers for this class and other classes.  This module has a subroutine of the form
SUBROUTINE SOLVE_BUNCH(FBUNCH, Parameter1, Parameter2, ...)
    TYPE (FuncBunch), INTENT(INOUT) :: FBUNCH
END SUBROUTINE SOLVE_BUNCH
I need to extend this example to solve many sets of FuncBunch equations (Func_Bunch or FuncV_Bunch) with an overriding constraint.  The idea I had was to create a new class of the form
TYPE, EXTENDS(FuncBase) :: FuncMultiBunch
    INTEGER, DIMENSION(:), ALLOCATABLE, PRIVATE :: DataSet
    INTEGER, DIMENSION(:), ALLOCATABLE, PRIVATE :: Topology
    ! 0 = single rate constraint, 1 = two rate constraints
    INTEGER, PRIVATE :: NFB
    CLASS (FuncBunch), DIMENSION(:), ALLOCATABLE, PRIVATE :: mFB
CONTAINS
    PROCEDURE :: Func => Func_MultiBunch
    PROCEDURE :: FuncV => FuncV_MultiBunch
    PROCEDURE :: FDJAC => FDJAC_MultiBunch
    PROCEDURE :: MaximumStep => MaximumStep_MultiBunch
END TYPE FuncMultiBunch
The idea would be to use a similar solver as the first, only the internals of the SOLVE_MULTIBUNCH would be to solve each FuncBunch individually with the level-one constraints involving sums or maxima applying.
The trouble I am having lies in getting the MULTIBUNCH to talk with the underlying SOLVE_BUNCH routine.  I cannot seem to use the mFB from FuncMultiBunch within SOLVE_BUNCH because FBUNCH is INTENT(INOUT) and any accessors I use would only be expressions or constants.  How might I accomplish this?  Might function pointers, a concept of which I am unfamiliar, help?
andrew_4619
Module_A  Submod_A1 Submod_A2 Submod_A3
Module_B  Submod_B1 Submod_B2
module A contains shared data and interfaces for A1, A2, A3 that have the contained routines
module B contains shared data and interfaces for B1, B2 that have the contained routines
So routines in A1 A2 and A3 can all see each other and can USE routines in B
routines in B1 and  B2 can all see each other and can USE routines in A
Arrange the modules in anyway that is logical you are not restricted by dependencies.
Li_L_
in type <FuncMultiBunch>
you can write a procedure to throw a mFB pointer
then
CLASS (FuncBunch),pointer:: ptr => <funcmultibunch>%throw_mfb_ptr(i)
call SUBROUTINE SOLVE_BUNCH(ptr,parameters...)
is that ok?
NotThatItMatters
Sounds good.  How would that change the original implementation and call sequence for SOLVE_BUNCH?  Do I need to explicitly call it with pointers to FuncBunch rather than FuncBunch targets?
I'm a little new to this concept.
Arjen_Markus
No, you don't need any special syntax to call a function via a function pointer (or a subroutine via a subroutine pointer). I find that a very elegant feature :).
Li_L_
i think i'm not completely got your meaning
in my understanding, if you wanna solve <mfb> in module funcMultiBunch, you can call solve_bunch(funcMultibunch%mfb...) directly, because private attr wouldn't stop the access from the same module
if you want call solve_bunch from the son module of funcMultiBunch, you have to write a pointer procedure to access the <mfb>
solver module is the ancient module of all other type modules.
NotThatItMatters
I am calling SOLVE_BUNCH from another module, call it the MultipleBunchConstraint module.  SOLVE_BUNCH itself exists in the SingleBunchConstraint module.  The definition of FuncBunch exists in the FuncBunch_Module module.  The definition of FuncMultiBunch exists in the FuncMultiBunch_Module module.
I know this seems a little extreme, but I have designed this to keep the class (type) definitions separate from the solvers and ultimately keep them separate from the modules which use the solvers.  This is to keep away from circular module and class references which have plagued the code in the past.
andrew_4619
SUBMODULE is the future it gets rid of all that circular dependence problem and stops you wasting your life on build cascades.
NotThatItMatters
So, with SUBMODULEs the idea is MultipleBunchConstraint is the module with SingleBunchConstraint the SUBMODULE?  Is accessibility from the outside of SingleBunchConstraint straightforward?
If you thought I was new to pointers, the newness with SUBMODULEs is quite a bit more.
andrew_4619
NotThatItMatters
Thank you.  I read a bit after I posted that last (idiotic) post and realized my idiocy.  You have described it in such a way that even I can understand.
NotThatItMatters
Okay, my code has come upon another impasse.  The FuncMultiBunch class is defined as follows:
    CLASS (FuncBunch), DIMENSION(:), POINTER, PRIVATE :: mFB
CONTAINS
    PROCEDURE :: Get_FB
TYPE (FuncBunch), DIMENSION(:), ALLOCATABLE, TARGET, PRIVATE :: FBactual
The PROCEDURE Get_FB is defined as follows:
FUNCTION Get_FB(this, N) RESULT(ptr)
    CLASS (FuncMultiBunch), INTENT(IN) :: this
    INTEGER, INTENT(IN) :: N
    TYPE (FuncBunch), POINTER :: ptr
    IF (N > 0 .AND. N <= this%Nn) THEN
        ptr => this%mFB(N)
    ELSE
        ptr => NULL()
    END IF
END FUNCTION Get_FB
The question lies in the use of Get_FB.  I am using it in various places within the enclosing module without compilation trouble.  However, in attempting to use it outside the module proper, I am getting Error #8346, A function reference cannot be used as the leftmost part-ref of structure component.  What am I missing?
IanH
Could you show a typical line of code that the error is reported against?  The message suggests that you have syntax akin to `object%Get_FB()%xyz`, which is not permitted.
Functions with a data pointer result that can sensibly return dissociated pointers make me a little nervous... it suggests to me that the function should instead be a subroutine.
NotThatItMatters
Here is a "one-liner" that fails.  As you might have guessed, I am changing the names to protect the ....
SUBROUTINE DO_SOMETHING(FMB, ...)
USE FuncMultiBunch_Module, ONLY : FuncMultiBunch
TYPE (FuncMultiBunch), INTENT(INOUT) :: FMB
REAL QFloat
QFloat = 0.0
QFloat = QFloat + FMB%Get_FB(M)%Get_A_Float()
END SUBROUTINE DO_SOMETHING
This line is giving me the headache.
NotThatItMatters
The following "equivalent" code compiles without error:
USE FuncBunch_Module, ONLY : FuncBunch
REAL QFloat
TYPE (FuncBunch) :: FBlocal
QFloat = 0.0
FPlocal = FMB%Get_FB(M)
QFloat = QFloat + FPlocal%Get_A_Float()
The creation of a local version of the FuncBunch TYPE allows the code compilation.  Now, provided I am not leaving uninitialized pointers or similar, will this actually work?  Is there anything inherently wrong with what I am trying to do?
NotThatItMatters
There is a typo here: FPlocal in the last line should be FBlocal.
IanH
Line 6 of the code in #13 has the invalid syntax I was referring to - you are not permitted to have a function reference to the left of the % .
Your function returns a pointer, which presumably (?) means that you want to reference the original object.  An assignment statement creates a copy of the value that is returned by the function reference.  Perhaps you want the temporary to be a pointer, and define it through pointer association.
TYPE (FuncBunch), POINTER :: FBLocal
FBLocal => FMB%Get_FB (M)
QFloat = QFloat + FBLocal%Get_A_Float ()
You can also use the associate construct to achieve the equivalent.
You need to think about what will happen when your function reference returns a dissociated pointer.
NotThatItMatters
What is the difference between my line and a reference within a PROCEDURE that is part of FuncMultiBunch which says
iItem = this%Get_FB(M)%Get_A_Number()
Are these items trouble?  They compile up fine.
I understand the idea of disassociation.  I have several catches.
IanH
If Get_FB really is a binding in the code in #17 (and not an array component reference), then the code should not compile. If the compiler is compiling such code, then I expect that would be regarded by the compiler support people as a bug.
NotThatItMatters
Sorry, that was not what I have in code.  What I have in code is
this%mFB(M)%Get_A_Number()
This is much different.  Sorry.
