C/Fortran Multithreading Seg Faults
phil_losie
Hi all,
I have a main program, written in C, that utilizes a threadpool of 12 threads (using pthreads) to perform parallel processing of some science data. Our group has a legacy Fortran subroutine that we need to call from each of thread to do the actual processing on a subset of the data. I posted previously on guidelines for thread-safe Fortran code (see http://software.intel.com/en-us/forums/showthread.php?t=79889) and incorporated those guidelines into my code. However, I'm stilling getting SIGSEGV errors in the Fortran section of my code. I've traced the problem to file I/O.
Here is the main C program code:
[bash]/*
 * Multithreaded C-Fortran mixed language test program
#include
#include
#include
#include
#include
#include "threadpool.h"
#define NUM_THREADS 12
#define NUM_JOBS 10
extern void fpa_(char *filename, int *io);
void job_thread(void *arg1, void *arg2);
int main(int argc, char **argv)
    threadpool tp;
    int i;
    char filenames[NUM_JOBS][100];
    int io[NUM_JOBS];
    /* Create a thread pool of 12 threads */
    tp = create_threadpool(NUM_THREADS);
    for (i = 0; i < NUM_JOBS; i++)
        /* Create a unique file name i.e. "./Files/file1.txt" */
        sprintf(&filenames[0], "/home/1060447/Test/Files/file%d.txt", i+1);
        /* Create a unique file I/O unit */
        io = 10+i;
        /* Add file name and I/O unit to threadpool job queue */
        printf("Main: queueing %s\n", &filenames[0]);
        dispatch_job(tp, job_thread, (void *) &filenames[0], &io);
    /* Wait a while for all the threads to do their thing */
    printf("Main: sleeping 20 secs...\n");
    sleep(20);
    printf("Main: waking up and destroying threadpool...\n");
    /* Clean up threadpool */
    destroy_threadpool(tp);
    printf("Main: exiting...\n");
    return 0;
/* Thread job function */
    char *filename = (char *) arg1;
    int *io = (int *) arg2;
    unsigned int len = strlen(filename);
    char string[len+1];
    sprintf(string, "%s", filename);
    fpa_(string, io);
    printf("->Thread %ld: Opened %s (len=%d) on I/O unit %d\n", pthread_self(), filename, len, *io);
[/bash]
Fortran subroutine code:
[bash]SUBROUTINE fpa(filename, io)
integer                  :: io
character*(*)            :: filename
open(io,file=filename,form='formatted',status='old')
close(io)
END SUBROUTINE fpa[/bash]
It creates a threadpool of 12 threads, each thread calls the job_thread function which in turn executes the Fortran fpa_ subroutine. The fpa_ subroutine simply opens and closes a unique file on a unique unit number. This program runs fine if I limit the threadpool to just 1 thread.
I compile the Fortran code using ifort (version 11.1) and options -openmp -pthread. The C code is compiled using gcc (version 4.1.2 in RedHat). The entire project is linked using gcc with the following options: -lpthread -mt -lm -L/opt/intel/Compiler/11.1/059/lib/intel64
Here is the program output (run from gdb debugger):
[plain](gdb) run
Starting program: /home/1060447/Test/test
[Thread debugging using libthread_db enabled]
[New Thread 0x40a00940 (LWP 5703)]
[New Thread 0x41401940 (LWP 5704)]
[New Thread 0x41e02940 (LWP 5705)]
[New Thread 0x42803940 (LWP 5706)]
[New Thread 0x43204940 (LWP 5707)]
[New Thread 0x43c05940 (LWP 5708)]
[New Thread 0x44606940 (LWP 5709)]
[New Thread 0x45007940 (LWP 5710)]
[New Thread 0x45a08940 (LWP 5711)]
[New Thread 0x46409940 (LWP 5712)]
[New Thread 0x46e0a940 (LWP 5713)]
[New Thread 0x4780b940 (LWP 5714)]
Main: queueing /home/1060447/Test/Files/file1.txt
Main: queueing /home/1060447/Test/Files/file2.txt
Main: queueing /home/1060447/Test/Files/file3.txt
Main: queueing /home/1060447/Test/Files/file4.txt
Main: queueing /home/1060447/Test/Files/file5.txt
Main: queueing /home/1060447/Test/Files/file6.txt
Main: queueing /home/1060447/Test/Files/file7.txt
Main: queueing /home/1060447/Test/Files/file8.txt
Main: queueing /home/1060447/Test/Files/file9.txt
Main: queueing /home/1060447/Test/Files/file10.txt
->Thread 1178638656: Opened /home/1060447/Test/Files/file2.txt (len=34) on I/O unit 11
->Thread 1157658944: Opened /home/1060447/Test/Files/file4.txt (len=34) on I/O unit 13
->Thread 1126189376: Opened /home/1060447/Test/Files/file5.txt (len=34) on I/O unit 14
->Thread 1094719808: Opened /home/1060447/Test/Files/file1.txt (len=34) on I/O unit 10
->Thread 1136679232: Opened /home/1060447/Test/Files/file6.txt (len=34) on I/O unit 15
->Thread 1147169088: Opened /home/1060447/Test/Files/file7.txt (len=34) on I/O unit 16
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x45a08940 (LWP 5711)]
0x000000335480a020 in pthread_mutex_unlock () from /lib64/libpthread.so.0[/plain]
A backtrace from the debugger:
[plain](gdb) bt
#0  0x000000335480a020 in pthread_mutex_unlock () from /lib64/libpthread.so.0
#1  0x00002aaaaab3861f in for__release_lun () from /opt/intel/Compiler/11.1/059/lib/intel64/libifcoremt.so.5
#2  0x00002aaaaab3ba58 in for_open () from /opt/intel/Compiler/11.1/059/lib/intel64/libifcoremt.so.5
#3  0x0000000000401d45 in fpa (filename=Quit[/plain]
I have converted the Fortran subroutine to C and the main program runs fine, regardless of the number of threads used. It seems that there is a mixed language issue between C and Fortran, or an incompatibility between the versions of ifort and gcc that I'm using. This is really frustrating!
Any help would be greatly appreciated!
Phil Losie
Ron_Green
where to begin ...
First, you cannot mix threading runtimes. So if you are using pthreads in C to create and manage the threadpool, DON'T compile the Fortran -openmp -pthreads
BUT you will need to use ifort -c -nofor-main -auto to tell the Fortran compiler that the main runtime is not Fortran AND -auto says to use stack for local variables (each thread will have a local copy)
Next, yes, mixed language issues. A C string is null terminated, a Fortran character variable has a length attribute and the characters. I don't have your create_threadpool so I can test everything, but I think the Fortran ought to look like this:
SUBROUTINE fpa(filename, io) bind(C, name="fpa")
use iso_c_binding
integer (kind=c_int), value, intent(in) :: io
type (C_PTR), intent(in), value :: filename
character (kind=C_CHAR), POINTER :: fort_filename(:)
call C_F_POINTER( filename, fort_filename )
open(io,file=fort_filename(1:),form='formatted',status='old')
close(io)
END SUBROUTINE fpa
and on the C side, call "fpa" and NOT "fpa_" - relying on name decoration is a bad practice.
We may need to tweak the fortran a bit, like I said, I haven't tested this.
TimP
You could use openmp threading in gcc compatibly with ifort, if you would use a recent enough gcc to support it. You would require the libiomp5 which comes with ifort, as that supports all the libgomp function calls as well as the Intel OpenMP calls.
phil_losie
Ronald,
Thansk for your quick reply! Attached is all my source code. I incorporated your suggested changes and I'm still getting a seg fault.
-Phil
Ron_Green
Hi Phil,
I've uploaded a working copy. You know, there are a TON of examples of passing Fortran strings to C, but going the opposite way there is very little. Here are some of the keys:
On the C side, I arbitrarily swapped the order of arguments to pass IO before the FILENAME. You can change those back, I debugged passing the int first since it was simpler, then added the string argument. Also, note the extern declaration and how the args are passed:
extern void fpa(int io, char *filename);
fpa(*io, string);
Now, the fortran:
SUBROUTINE fpa(io, filename) bind(C, name="fpa")
use iso_c_binding
implicit none
type(C_PTR), value :: filename
character*1 , pointer :: ffilename(:)
integer, parameter :: MAX_FILENAME_LENGTH=200
character (len=MAX_FILENAME_LENGTH) :: ofile = " "
!...interface to C strlen function ...
interface
function strlen(str) bind(C,name='strlen')
use ISO_C_BINDING
implicit none
type(C_PTR),value :: str
integer(C_SIZE_T) strlen
end function strlen
end interface
integer :: j,fnsize
!...find the input C string length
fnsize = strlen(filename)
!...create a Fortran point to an array of characters
call c_f_pointer( filename, ffilename, [fnsize] )
!...copy the individual chars to a character variable
do j=1,fnsize
ofile(j:j) = ffilename(j)
end do
open(io,file=trim(ofile),form='formatted',status='unknown')
close(io)
END SUBROUTINE fpa
The tricks were to determine the C string size calling the C lib strlen, then creating an equivalent Fortran pointer to the array of characters passed in by C, then copying those individual characters to a "normal" Fortran character variable.
In the attached code, you'll need to modify test.c to put your path into the filename prototype, as I left my path in there.
ron
phil_losie
Ron,
I'm still getting a seg fault with your updated code. Sometimes, it runs correctly. It runs correctly 100% of the time if I change the number of threads to 1.
Ron_Green
A colleague pointed out to me that when we have a C main calling IO routines in the Fortran runtime library, it is necessary to call for_rtl_init_ () prior to using the FRTL, then set reentrancy property, and finally at the end of the C main, call for_rtl_finish_ () to clean up.
I've attached a new sample. Note the changes to test.c. Also, the C code needed an include from the Fortran include dir for the symbolic name for reeentrancy setting. Check the makefile. Also, in the makefile I have a non-default path to my compiler so fix the FINC and LFLAGS to point to your compiler.
ron
phil_losie
Ron,
I tried this out and it works! Thanks so much for your help. I would have never figured this out on my own. By the way, how did your colleague know to call FRTL prior to invoking Fortran? Is there any documentation in case I run into other problems down the road?
Thanks again!
-Phil
This is documented in the "Building Applications" manual on mixed-language programming. The for_rtl_init routine is documented in the A-Z Reference part of the Language Reference.
