C string from Fortran string
Nick2
My subroutine declares,
character*15000 SQLStmtStr
character*15000 SQLStmtStrA
where SQLStmtStr is an incoming argument. My goal is to make a C string to call
iRet = SQLExecDirect(StmtHndl,SQLStmtStrA,len)
And I'm not sure how to accomplish this...if I try
SQLStmtStrA=ADJUSTL(TRIM(SQLStmtStr))//char(0)
Then SQLStmtStrA ends up with garbage characters.
If I try
len=
len_trim(SQLStmtStr)
SQLStmtStrA=SQLStmtStr(1:len)//char(0)
Then the code stops execution when I step over that last line.
Errr...what am I doing wrong?
Nick2
SQL was kind enough to let me send in the Fortran string (and the length) - so this issue is resolved. But it would still be nice to know where this weird behavior came from.
My guess is that it's because you declared the arguments as CHARACTER*15000 rather than CHARACTER(*) and that the TRIM was seeing garbage at the end of the string.
When you say that the code "stops execution", what do you mean? Was there an error message?
Nick2
I saw an error that looks like this:
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
A very peculiar thing is thatmy SQLStmtStrA has an initial value that starts with a funny character (a square).
I also just tried re-defining
character(*) SQLStmtStr
but that didn't help
Nick2
This gets even more fun!
I also have
character*255 ColStr
and when I call
iRet = SQLBindCol(StmtHndl,int(1,2),1,ColStr,255,0)
that's when my SQLStmtStrA seems to get corrupt.
Do the SQL routines expect the lengths to be passed by value? (And if so, do you have interfaces for them saying so?)
Nick2
Yes and yes. (Though I tried the last argument by reference, since it wasn't really clear). Does anything stand out from how I wrote my interface? (Microsoft definition of SQLBindCol follows)
C
C see http://msdn2.microsoft.com/en-us/library/ms711010.aspx
C see also ODBC32.lib in notepad
integer(2) function SQLBindCol
& (StatementHandle,ColumnNumber,TargetType,
& TargetValuePtr,BufferLength,StrLen_or_Ind)
CVBASIC UNCOMMENT START
!DEC$ATTRIBUTES C, ALIAS: "_SQLBindCol@24":: SQLBindCol
!DEC$ATTRIBUTES VALUE:: StatementHandle
!DEC$ATTRIBUTES VALUE:: ColumnNumber
!DEC$ATTRIBUTES VALUE:: TargetType
!DEC$ATTRIBUTES REFERENCE:: TargetValuePtr
!DEC$ATTRIBUTES VALUE:: BufferLength
!DEC$ATTRIBUTES VALUE:: StrLen_or_Ind
CVBASIC UNCOMMENT END
integer(4) StatementHandle
integer(2) ColumnNumber
integer(2) TargetType
character(*) TargetValuePtr
integer(4) BufferLength
integer(4) StrLen_or_Ind
end function
SQLRETURN SQLBindCol(
SQLHSTMTStatementHandle,
SQLUSMALLINTColumnNumber,
SQLSMALLINTTargetType,
SQLPOINTERTargetValuePtr,
SQLINTEGERBufferLength,
SQLLEN *StrLen_or_Ind);
Oh my goodness yes. Here's your problem:
Make this instead:
!DEC$ ATTRIBUTES STDCALL, DECORATE, ALIAS:"SQLBindCol" :: SQLBindCol
You've told ifort to use the C calling convention for a STDCALL routine, which will corrupt the stack on every call. That @24 on the end of the alias is the giveaway that the routine is STDCALL (as all Win32 API routines are.)
Nick2
Steve, you're Da Man!!!
Make sure you make a similar edit on your other interfaces.
