CLASS argument mismatch
John4
Valued Contributor I
In the core below, I get an error stating that the characteristics of the first argument of the actual procedure do not match those of the dummy procedure.
module mod1
    type, abstract :: t1
        integer :: dummy1 = 0
    contains
        procedure :: execute
    end type
    abstract interface
        subroutine i_t1(this)
            import
            class(t1), intent(INOUT) :: this
        end subroutine
    end interface
contains
    subroutine execute(this, proc)
        procedure(i_t1) :: proc
        call proc(this)
    end subroutine
end module mod1
module mod2
    use mod1
    type, abstract, extends(t1) :: t2
        integer :: dummy2 = 0
    contains
        procedure :: handler2
    end type
contains
    subroutine handler2(this)
        class(t2), intent(INOUT) :: this
    end subroutine
end module mod2
module mod3
    use mod2
    type, extends(t2) :: t3
        integer :: dummy3 = 0
    contains
        procedure :: handler3
        procedure :: do_something
    end type
contains
    subroutine handler3(this)
        class(t3), intent(INOUT) :: this
    end subroutine
    subroutine do_something(this)
        call this%execute(handler2)
        call this%execute(handler3)
    end subroutine
end module mod3
Even if t2 is not an abstract type, there seems to be no way of passing handler2 or handler3 to the type-bound procedure (I already tried the f95 way as well).
Is it a bug in the implementation? Or is the compiler right at complaining here?
kostas85
Hello John
How about changing the handlers 2 as :
    end subroutine
    end subroutine
and using  nopass:
        procedure, nopass :: handler2
        procedure, nopass :: handler3
This should compile I think
John4
I'm not really looking for workarounds to make it just compile, and that particular workaround doesn't work for me ---since, in the actual code, handler2 and handler3 would have to invoke type-bound procedures from t2 and t3, respectively.
It just seems like weird behavior to me, and I would like to be certain that I'm not doing something wrong.
The following code fails to compile as well, so the issue is not related to the ABSTRACT attribute of t1:
module mod1
    type :: t1
    contains
    end type
    abstract interface
            import
        end subroutine
    end interface
contains
        call proc(this)
    end subroutine
end module mod1
module mod2
    use mod1
    type, extends(t1) :: t2
    contains
    end type
contains
    end subroutine
        procedure(i_t1), pointer :: pp
        pp => handler2
       call this%execute(pp)
    end subroutine
end module mod2
FortranFan
I think the compiler is right; you can comb through the Fortran standards documentation and see if you find something that supports your case, but I'll be surprised if you find any other compiler that accepts this.
Separately, from a polymorphism and OO design point of view, your code doesn't make much sense to me and I can't identify the design pattern and a practical value of such an approach.  Why do you need a construct such as [fortran]call this%execute(handler2)[/fortran] when you can do [fortran]call this%handler2()[/fortran] directly and accrue all the benefits of class design, inheritance, and polymorphism in this simpler way?
This is not a bug. Unlike with direct calls, procedure pointers must have the SAME interface, not just compatible interfaces.
John4
when you can do
Most of the code in this forum doesn't have to make sense.  It only has to prove a point (in this case, the point is showing the error thrown by the compiler).  It's actually the second time you fail to realize that.
In the actual code the base abstract class implements a comparison of methods for doing certain things, and each handler implements a particular method.  The this%execute() procedure would actually be this%addSomeMethodOfComputingThings(), and just stores a pointer to the procedure passed as argument, to be called later; and it stores many of those. Another procedure in the base class calls them one after another, compares and outputs the results ---and for some reason that makes sense to me.
The actual code compiled and ran just fine with a previous version of ifort (even with some of the methods being in separate libraries, loaded through dlfcn and C_F_PROCPOINTER), but with the latest version it throws an error.
John4
Steve, in the original code I posted, there are no procedure pointers.  It's just procedures being passed as arguments.  The argument of each of those procedures being passed, satisfies the required interface (since it's of the same class), but the compiler sees differently.
Right - we fixed a bug. The standard says:
"If proc-pointer-object has an explicit interface, its characteristics shall be the same as proc-target except that proc-target may be pure even if proc-pointer-object is not pure and proc-target may be an elemental intrinsic procedure even if proc-pointer-object is not elemental." [F2008, p160, lines 6-8]
John4
Steve,
The text you cite mentions "explicit interface", and that made me think of a somewhat riskier approach: Is the following code valid? Or does it just work because of a yet-to-be-fixed bug?
module mod1
    type :: availableMethods
        procedure(i_compute), pointer, nopass :: proc => NULL()
    end type
    type :: compute
        type(availableMethods) :: methods(2)
    contains
        procedure :: addMethod
    end type
    abstract interface
        subroutine i_compute(this)
            import
            class(compute), intent(INOUT) :: this
        end subroutine
    end interface
contains
    subroutine addMethod(this, proc)
        procedure() :: proc
        integer :: i, idx
        idx = 0
        do i = 1, SIZE(this%methods)
            if (.NOT. ASSOCIATED(this%methods(i)%proc)) then
                idx = i
                exit
            endif
        enddo
        if (idx == 0) then
            write (*,'(A)') 'Cannot add more'
            return
        endif
        this%methods(idx)%proc => proc
    end subroutine
    subroutine execute(this)
        integer :: i
            if (.NOT. ASSOCIATED(this%methods(i)%proc)) cycle
            call this%methods(i)%proc(this)
        enddo
    end subroutine
end module mod1
module mod2
    use mod1
    type, extends(compute) :: implement
        integer :: dummy = 0
    contains
    end type
contains
    subroutine handler(this)
        class(implement), intent(INOUT) :: this
        call this%do_something()
    end subroutine
        write (*, '(A)') 'Doing something'
    end subroutine
end module mod2
use mod2
type(implement) :: a
call a%addMethod(handler)
call a%execute()
end
I quoted the wrong part of the standard. You're passing a procedure dummy argument. But the same issue arises - the characteristics of the arguments must be the same and yours are not.
