29657 Discussions
COMPILER BUG: contiguous statement in interface
DataScientist
Valued Contributor I
Is the following code non-compliant? or is it an ifort compiler bug?
program hello
    interface test
        function test_func(array)
            real :: array(:,:)
            contiguous :: array
        end function
    end interface
end program hello
DataScientist
at was guess, that for confirming!
Arjen_Markus
Since the keyword contiguous is part of the interface of a routine (contiguity allows for further optimisation, IIUIC), I would say the program above is definitely conforming. gfortran accepts it as is. If I change the code to:
real, contiguous :: array(:,:)
Intel Fortran is happy too.
DataScientist
