Call Fortran from C
lxh37
Hi, I have many codes in Fortran and I wrapped it by C to create .dylib in Mac and I can call it from Ruby On Rails.
Recently we have lots of trouble with Mac Server and we want to transfer everything to Linux, but the Fortran code
will not compile in Linux, the error message is !!DEC$ ATTRIBUTES DLLEXPORT, C :: addsize is not supported
in this platform. Is there a way to get around this without having to rewrite Fortran codes using  ISO_C_BINDING?
Thanks!
Liz
DLLEXPORT is not for Linux. Just take that out - nothing else needs to change.
lxh37
Thanks! I have commented the line out and compiled the code, but doesn't work properly in Linux,
same code worked in Mac...
Liz
See your other thread - if it's the same code it should not have worked on Mac either. You don't say how it "doesn't work", though.
lxh37
The error message I got from Ruby On Rails is error with external library, the other thread I tried to create a much simple code and use iso_c_binding to see if the error could be with Ruby On Rails...
I can't help with the Ruby On Rails error. Let's see if we can get the Fortran-C version working first.
