Calling DOS exe
ferrad01
Is it possible to call a DOS executable from Intel Fortran? If so, can you point me to some docs.
ferrad01
Quoting - ferrad01
I found it: i = system("dir >x.x")
TimP
Quoting - ferrad01
The SYSTEM and SYSTEMQQ functions are described in the documentation which comes with ifort. This permits passing a command line to the shell under which the Fortran .exe was started., so it would have to be a .exe which works in that shell.
