Can anyone direct me to an example where a subroutine in a Fortran dll is called with more than one array? I am calling form Delphi but a C example is as good.
I do not have problems passing a mixture of integers, reals and one array. When I try to pass two arrays I get an acces violation when I try to address array number two in the Fortran dll.
Here is the Delphi code:
var
Form1: TForm1;
procedure TestArray(Length: integer; AInteger: array of integer; RReal: Array of double); stdcall; external 'testdll.dll';
implementation
{$R *.DFM}procedure TForm1.Button1Click(Sender: TObject);
var
I : integer;
AInteger : array of integer;
AReal : array of double;
Length : integer;
begin
//Transfer of integer and real arrays
Length:=4;
setlength(AInteger,Length);
setlength(AReal,Length);
for I:=0 to Length-1 do AInteger:=I;
for I:=0 to Length-1 do AReal:=I*3/2;
TestArray(Length,AInteger,AReal)
end;
And here is the fortran code
subroutine TestArray(Length, AInteger,AReal)
!DEC$ ATTRIBUTES DLLEXPORT :: TestArray
!DEC$ ATTRIBUTES STDCALL :: TestArray
!DEC$ ATTRIBUTES ALIAS : 'TestArray' :: TestArray
implicit none
integer*4 Length
integer*4 AInteger(1)
real*8 AReal(1)
integer I
c-------Program
write(10,*) 'Program test1'
write(10,*) Length
do I=1,Length
write(10,*) AInteger(I)
end do
do I=1,Length
write(10,*) AReal(I)
end do
write(10,*) 'End TestArray'
end subroutine TestArray
The first loop writing the AInteger array works but when AReal is written I get an access violation. The fort.10 file look like (this is what is written until it adresses the AReal array):
Program test1
4
0
1
2
3
Thanks for your help.
I tried to change the Delpi code to:
var
AInteger : array [1..4] of integer;
AReal : array [1..4] of double;
Length : integer;
begin
//Transfer of integer array
Length:=4;
for I:=1 to Length do AInteger:=I;
for I:=1 to Length do AReal:=I*3/2;
TestArray(Length,AInteger[1],AReal[1])
but with the same result - I still gets an acces violation. I also tried to declare the array in the fortran code to assumed size
integer*4 :: AInteger(*)
real*8 :: AReal(*)
but that the same. Do you think I have to give it up?
procedure TestArray(Length: integer; var AInteger: integer; var RReal: double);That ought to work. You can also print LOC(RReal) (RReal^) on Delphi and Fortran sides and see if they match.
You are a hero - it works - thanks for your quick help.
Esben
Just for your information - adjustable arrays in Delphi also works:
procedure TestArray(Length: integer; var AInteger: integer; var RReal: double); stdcall; external 'testdll.dll';
var
I, J, LA :integer;
Length : integer;
begin
Length:=4;
TestArray(Length,AInteger[0],AReal[0])
end;
And in Fortran
subroutine TestArray(Length,AInteger,AReal)
implicit none
integer*4 Length
real*8 :: AReal(*)
integer I
c-------Program
write(10,*) Length
do I=1,Length
end do
do I=1,Length
end do
