29426 Discussions
Calling function in C++ Dll from Compaq Visual Fortran
jk
I am trying to call a function in C++ Dll module and passing two character variables. It works fine with one variable but when the second is added I get an error "Stack trace terminated abonormally". My fortran code is as follows:
INTERFACE
integer function GetRandomChar(char1, char2)
!DEC$ ATTRIBUTES C,DLLIMPORT
!DEC$ ATTRIBUTES ALIAS:'_GetRandomChar'::GetRandomChar
!DEC$ ATTRIBUTES REFERENCE :: char1, char2
character*(*) :: char1, char2
end function GetRandomChar
end interface
tmpchar1 = 'text1' //char(0)
tmpchar2 = 'text2'//char(0)
tmpCharid = GetRandomChar(tmpchar1, tmpchar2)
The C++ Dll code is as follows:
In header file:
extern "C" __declspec(dllexport) int GetRandomChar(char*, char*);
In CPP file:
extern "C" __declspec(dllexport) int GetRandomChar(char *test5, char *test6)
ofstream myfile("AAA.txt");
//myfile.open ("C:\\\\work\\\\AAA.txt");
myfile << "Writing this to a file.\\n";
myfile << test5;
myfile << "\\n";
myfile << test6;
myfile.close();
When I try to access the test6 I get the error. If I comment out "myfile << test6" it runs without problems. What could be wrong?
Lorri_M_Intel
I modified your code enough to make it compile and link, and I did not see the same error.
F:\tests>type aaa.txt
text1
text2
As written in this note, the attributes on the interface declaration to GetRandomChar do not compile. Please make sure that the real code is correct.
jk
Thank you for your answer. I will have a look at it.
