29642 Discussions
Can not see source code when getting run-time error
tung_nguyen
I got an pop-up window with "Visual Fortran run-time error" when my application had an "out of bound" run-time error but the information I got from it does not provide the source code information (I only got the image name and PC but don't have the routine name, line number, etc). Note that I am able to see source code when my application had a floating point exception (fpe)when attached it to Visual Studio.
Thanks in advance for any help,
Tung.
If you get this error in Visual Studio, does it break and show you the source line? If you built a Release configuration, you will also need to enable the Traceback feature (/traceback).
tung_nguyen
It does not break and show the source line when I have an exception which is out of bounds checked during run-time but it does break and show the source line when I have an floating point exception. I'm running my application built in "Debug".
What version are you using? Some older versions had that behavior. I think 10.1 and later break.
