Can someone please help?
ktluu78
I need some help urgently. I am currently using CVF version 6.1.0 with windows xp. It was working fine before. Now, it is playing up on me. In developer studio, if I go File--> Open or Project--> Add to Project--> Files, i get the error dialouge " Microsoft Developer Studio has encountered a problem and needs to close ......." and if I click on the Debug button, it gives " Unhandled exception in DFDEV.EXE(DEVSHL.DLL):0xc0000005: Access violation.
Having played with it (which included googling it), It's supposed to be a known issue with Microsoft visual studio but none of the solutions I've tried have fixed the problem ( I have tried uninstalled-reinstalled it, Installed service packs downloaded from Microsoft website (by the way, I could nt install the service packs)...
I am not an expert in CVF or VC and I am desperate for some help. So can someone please help?
Many thanks
jimdempseyatthecove
Try
Start | Visual Studio | Open Project | YourProjectNameHere
Then launch a 2nd instance of VS
Start | Visual Studio | Create Project | fixYourProjectNameHere
(notice different name)
And then finish creating the new project/solution using same settings as old project/solution. Then go about adding the new project to the new solution.
Once you have a working solution you can decide on renaming the solution.
Jim Dempsey
mshippen
ktluu78,
Were you ever able to resolve this problem? I am getting the exact same error and the suggested fix didnt work
thanks,
Mack
jugoslavdujic2
As a first resort, delete the YourSolutionName.suo file from the project directory.
For CVF, that would be the .opt file.
