Can't build with ifort19
仁义_许_
macosx10.14
xcode 9.4
/ifort-19_0_0_117:: error #10401: error running 'xcrun -find clang'
in the command line:
source <install_dir>/bin/compilervars.sh intel64
manpath: error: unable to read SDK settings for '/Library/Developer/CommandLineTools/SDKs/MacOSX.sdk'
ifort **.f90
ifort: error #10401: error running 'xcrun -find ld'
Juergen_R_R
Valued Contributor II
You most likely have to upgrade to Xcode 10 and upgrade the command-line tools. If that doesn't help, try to execute open /Library/Developer/CommandLineTools/Packages/macOS_SDK_headers_for_macOS_10.14.pkg
This is because the system headers are no longer installed as default in Mojave (macOS 10.14)
仁义_许_
ifort2019 does not support xcode10
I setup the command line tools for Xcode9 and then build it successfully
Thx!
