Trying to compile and link fortran files to the CPP project, linked as an static library file(CPP calls FORTRAN) will case a following errors,
Undefined symbols for architecture x86_64:
"_for_write_seq_lis", referenced from:
_coeff in liblib_rastres.a(coeff.o)
"_for_write_seq_lis_xmit", referenced from:
ld: symbol(s) not found for architecture x86_64
Calling one of the fortran library functions from main.cpp looks like an external C functions,
extern "C"
void coeff(double[],double[],double[],double[],double[],double[],double[],double[],double[],double[],double[]
,double[],double[],double[],double[],double[],double[],int**,double[],double[],double[],int);
There is no problems with my project external names, when linked. However, there is an internal Intel library linking error.
My OS is OSX 10.13.14, IDE: Netbeans 8.2, Compiler: Intel Parallel Studio (Composer) 2018 with Intel cpp/fortran compilers.
NETBEANS CPP PROJECT: QT application with Intel CPP.
NETBEANS FORTRAN PROJECT: Static library with Intel Fortran.
FORTRAN TEXT:
subroutine coeff(V,a1,b1,c1, d1, a2, b2, c2, d2, a3, b3, c3, d3, a4, b4, c4, d4, Iuzl3d, X3d, Y3d, Z3d, N_el) BIND(C,name="coeff")
use, intrinsic :: ISO_C_BINDING
implicit none
integer, parameter :: N = 3, M = 4
integer(kind=C_INT),intent(in) :: N_el
integer(kind=C_INT),intent(in) :: Iuzl3d(10,N_el)
real(kind=C_DOUBLE),intent(in) :: X3d(N_el), Y3d(N_el), Z3d(N_el)
real(kind=C_DOUBLE),intent(out):: V(N_el),a1(N_el),b1(N_el),c1(N_el),d1(N_el),a2(N_el),b2(N_el),c2(N_el),d2(N_el),a3(N_el)
real(kind=C_DOUBLE),intent(out):: b3(N_el),c3(N_el),d3(N_el), a4(N_el), b4(N_el), c4(N_el), d4(N_el)
integer(kind=C_INT) :: i,k
real(kind=C_DOUBLE) :: aa(N,N)
real(kind=C_DOUBLE) :: x(M),y(M),z(M)
real(kind=C_DOUBLE),parameter :: zero=0.0_C_DOUBLE, one = 1.0_C_DOUBLE, six = 6.0_C_DOUBLE
interface
function detf(aa)
double precision :: detf
double precision, intent(in) :: aa(3,3)
end function detf
end interface
do i=1,N_el
x(1:M)=X3d(Iuzl3d(1:M,i))
y(1:M)=Y3d(Iuzl3d(1:M,i))
z(1:M)=Z3d(Iuzl3d(1:M,i))
d1(i) = detf(aa)
enddo
function detf(aa)
implicit none
double precision :: detf, det
det = aa(1,1)*aa(2,2)*aa(3,3)-aa(1,1)*aa(2,3)*aa(3,2)-aa(1,2)*aa(2,1)*aa(3,3)
detf = det + aa(1,2)*aa(2,3)*aa(3,1)+aa(1,3)*aa(2,1)*aa(3,2)-aa(1,3)*aa(2,2)*aa(3,1)
end function detf
Thank you for any help,
Malik
Since you generated Fortran static library, it only has your Fortran code and not any other supporting library code that your Fortran code needs to function.
Suggestion: try linking your resulting executable using "ifort": it will know, what other libraries need to be added at the link stage to satisfy the dependencies of your code. Alternatively, you could compile your Fortran code into a dynamic library (.so), in which case all the Fortran code dependencies will be satisfied at .so link time.
Thank you,
--Eugene
Thank you Eugene, I will try...
Malik.
Thank you again Eugene, it works with ifort -staticlib tool!
Malik.
