or common blocks in IDB. I've tried various combinations of the Local Variable Storage and Name Case Interpretation build options with no joy. Is this a known problem or am I don't something wrong (I'm using Xcode to build the project and idb interactively to debug it).
Best,
Dick Munroe
If you try to access (print, etc.) a Fortran module or common using the name in the source code, the debugger may not be able to find it. As a workaround, the you can try prepending '_' to the name. For example, in the source code, if you have a common called "com":
(idb) print _com
(idb) print _com
