Cannot find ifort.exe
fkksa_u_
I have installed Intel Visual Composer XE 2013 with Microsoft Visual Studio 2012. When compiling in Aspen Plus V7.0 Simulation Engine Window i get "ifort.exe not found in "PATH".
Thank you for your help
IanH
You probably need to set environment variables up correctly for the compiler inside the simulation engine window (which is just a command prompt).  Try running:
"%IFORT_COMPILER13%\bin\compilervars.bat" ia32
(assuming Aspen needs a 32 bit compile - its been a few years since I've used it so I'm not sure what the go is today.)
in the simulation engine window, before you start your Aspen job.
