29487 Discussions
Cannot open Resource Editor in VS 2005
hbell1
I had created a dialog (a resource file with rc extension) with VS 2003 and now that I upgraded to VS 2005 I cannot open it (the rc file) with the Resource Editor.When I right click on the file from Solution Explorer, select Open With, select Resource Editor, the MS Visual Studio error message says:
"The file cannot be opened with the selected editor. Please choose another editor."
The project compiles and executes fine with the existing rc file, so I don't know why I can't edit it withResource Editor.
What's going on?Any ideas?
Harry
Are you using the VS2005 Premier Partner Edition (VSPPE) bundled with the compiler or a separately purchased VS2005. If VSPPE, the resource editor is not included, as stated in the release notes. If the latter, download and install Service Pack 1 for VS2005.
hbell1
Steve,
Here is what I have installed when I click "About Microsoft Visual Studio" (I seem to have VSPPE and Service Pack 1 installed):
Microsoft Visual Studio 2005
Version 8.0.50727.762 (SP.050727-7600)
Microsoft .NET Framework
Version 2.0.50727 SP1
Installed Edition: IDE Standard
Intel Fortran Compiler Integration
Intel Fortran Compiler Integration for Microsoft Visual Studio 2005, 10.1.3948.2005, Copyright (C) 2002-2007 Intel Corporation
Microsoft Visual Studio 2005 Premier Partner Edition - ENU Service Pack 1 (KB926601)
This service pack is for Microsoft Visual Studio 2005 Premier Partner Edition - ENU.
If you later install a more recent service pack, this service pack will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/926601
Visual Studio Package Load Analyzer 1.0
A utility that analyzes package load failures in Visual Studio 2005.
Harry
VSPPE means no resource editor - sorry. Microsoft insists that the resource editor is part of their Visual C++ product and does not license it to the "Visual Studio Integration Partners".
My advice is to reinstall VS2003 and Intel Visual Fortran - the bundled VSPPE offers fewer features than VS2003 and is intended for people who do not already have a supported VS.
hbell1
Steve,
Before I go through the downgrade of VS2005 to VS2003 I have a couple questions:
Will I lose my project file settings in the uninstall/install process or will VS2003 be able to use the VS2005 project settings without any changes?
Just in case, is there a quick way to print out all of my project settings?
Harry
You can't open a VS2005 Solution in VS2003, but you can create a blank solution and add the Fortran project to it from the .vfproj file. I suggest deleting the .sln and .suo files before trying this.
hbell1
Steve,
When I uninstalled VS2005 then installed VS2003 it no longer has Intel Visual Fortran integrated. Do I now need to uninstall and re-install Intel Visual Fortran? Which versions of IVF will work with VS2003?
Harry
Les_Neilson
Valued Contributor II
If you have IVF already installed then youmay only need to run theintegration part of the install.
IVF v9or v10 will work with VS2003.
Les
Les is correct. Run w_ide_p_10.1.xxx.exe which you will find in the Program FilesIntelDownloadIntelFortranCompiler10.1Installs folder.
cquni
I am using Intel Visual fortran for developing some engineering applications. I have convered my application from console application to quickwin application for making it more user friendly. Unforunatley, I can not develop dialogs as my resource editor is not working. How can I add some dialog boxes to my application?
thanks,
Mohammad
Jugoslav_Dujic
Try http://www.resedit.net/. I didn't play with it too much, but looks like a quite decent replacement for the built-in resource editor. You can add the .rc file to your Visual Studio project and it will get compiled automatically.
algraham
I am developing an OpenGL application and I am considering upgrading from Intel Fortran 9 to version 11. Can anyone tell me if theincludedVisual Studio 5 Premier Partner Edition supports full multiple-document-interface applications, and if it provides the OpenGL libraries?
Thanks very much.
alg
OpenGL libraries are provided and there's no issue creating MDI applications.
j_clausen
Hi everyone.
Ok, I am a little bit confused now. I have installed the same version of Microsoft Visual Studion as the one quoted above
I would like to work with my Intel Visual Fortran 10.0 using Visual Studio. But from this thread I get the impression that Intel Fortran does not work with the Visual Studio 2005 professional edition?
Actually my Visual Studio cannot reckognize .f90-files (i.e. comments don't apear green and keywords in blue, etc.)and I can't create Fortran projects. If it indeed is possible to work with Intel Fortran from Visual Studio 2005 can anyone tell me how I can make Visual Studio 2005 "see" that I have Intel Visual Fortran installed?I have spent a long time browsing through the menus in Visual Studio (and the internet) to find a way to "add a compiler" or similar...
I can compile myFortran source files from the command line, so theIntel Fortran compileris working.
Best regards
J. Clausen
Les_Neilson
Quoting - j_clausen
Hi everyone.
Best regards
J. Clausen
Yes it does work with VS2005. The fortran should be installed *after* installing VS2005 andits Service Pack 1, and you need to choose the "Visual Studio integration"
A re-install of the fortran compiler (or at least the integration part)should fix it.
Les
j_clausen
Quoting - Les Neilson
Les
Ahh.. that's how it should be done. It worked like a charm. Thank you very much for the quick and very helpfull answer.
Best regards:
J. Clausen
