29246 Discussions
Cannot watch module variables in IVF 2015
Amalia_B_
I've been using this feature since MS 2008-2012 and all previous versions of IVF (and Composer) and now just updated to MS Visual Studio 2013 (Ver. 12.0.30723.00 Update 3) and Intel Parallel Studio XE 2015 Composer Edition for Fortran Windows (w_fcompxe_2015.0.108) and every time I try to watch a variable contained in a module, I get "undefined variable .....".  I access the variable by modulename::variablename  and always get the same error or undefined variable response.  This worked in previous versions.
Is this a known bug?
Amalia
mecej4
I cannot reproduce the problem. I have a module with the following code:
MODULE common_refnum
   IMPLICIT NONE
   integer, parameter :: dp=kind(1d0)
   INTEGER, SAVE :: nprob, nfev, njev
END MODULE common_refnum
This module is USEd in the main program, and the VS debugger shows the module variables in the watch window whether I refer to the variable with the "common_refnum::" or "common_refnum_mp_" prefixes.
FortranFan
Amalia
Works fine for me too, so I doubt there is a bug.
During installation of Intel Parallel Studio, the integration step of Intel Fortran with Visual Studio may have encountered some problems or you may have updated Visual Studio 2013 after installing Intel Parallel Studio which "broke" something in your Intel Fortran-VS integration.  You may want to consider "repairing" your Intel Parallel Studio installation by rerunning the install script and selecting the "Repair" option.  If that doesn't work, you can try uninstalling and installing Intel Parallel Studio.
