Cast Pointer to another type
merik
Is there a way to cast a pointer to another type.
Here is an example that does not work:
[cpp]type ABC
CHARACTER*1 DUM(100)
end type ABC
type(ABC), pointer :: BOB
integer*4 ,pointer :: F1
F1 => BOB%DUM(80)[/cpp]
You sure you want F1 to be just an integer scalar? Anyway, here's how you do it.
[cpp]use, intrinsic :: iso_c_binding
type ABC
end type ABC
integer*4, pointer :: F1
call C_F_POINTER(C_LOC(BOB), F1)[/cpp]
merik
type ABC
end type ABC
I am trying to force F1 to use the four bytes from DUM at the 80th position. I would perfer a scalar. I'm not able to try it right now but will this work with call C_F_POINTER(C_LOC(BOB(80)), F1)
I assume you mean BOB%DUM(80). Yes, it should.
merik
Yes, you are correct. This worked fine. I am trying to do the same thing for arrays but that does not seem to work.
I did:
integer*4, pointer :: F2(:)
call C_F_POINTER(C_LOC(BOB%DUM(84)), F2)
But I get an exception (Access violation) with C_F_POINTER. Any clues?
I'd need to see a complete example. Did you specify the SHAPE argument to C_F_POINTER? This works:
[cpp] use, intrinsic :: iso_c_binding
 type ABC
 end type ABC
 integer*4, pointer :: F1(:)
 allocate (BOB)
 do i=1,100
 BOB%DUM(i:i) = char(i)
 end do
 call C_F_POINTER(C_LOC(BOB%DUM(84)), F1,[4])
 print *, F1(1)
 end[/cpp]
Did you allocate BOB?
merik
 type ABC
 end type ABC
 allocate (BOB)
 do i=1,100
 end do
 print *, F1(1)
 end[/cpp]
Yes, I allocate BOB in C. The actual code is:
[cpp]      module mymod
      use, intrinsic :: ISO_C_BINDING
      implicit none
      type, bind(C) :: xrftest_t
      end type xrftest_t
      type(C_PTR), bind(C) :: xrftest
!ms$attributes dllimport :: xrftest
cDEC$ ATTRIBUTES EXTERN  :: XRFTEST
      type(xrftest_t), pointer :: BOB
      end module mymod
      SUBROUTINE  FUNNY()
      USE mymod
!MS$ ATTRIBUTES DLLEXPORT :: FUNNY
C
      IMPLICIT NONE
      ! Convert C pointer to Fortran pointer
      call C_F_POINTER(xrftest, BOB)
      call C_F_POINTER(C_LOC(BOB%DUM(81)), F1)
      call C_F_POINTER(C_LOC(BOB%DUM(85)), F2,[4])
      F1 = 77
      F2(1) = 88
      F2(2) = 99
      F2(3) = 101
      F2(4) = 102
      END
      [/cpp]
Thanks, It works great.
