Changing font inside edit boxes
rswy
Is it possible to change font properties of text within edit boxes?
I have an application that requires the thickness of a line to be altered in a dialog box application.Can it be done by writing text(hyphen) into edit boxes or is there some other way of doing it?
--rswy
Intel_C_Intel
All the text within a specific edit box would have to be the same font.
To get a line in the dialog box use picture - rectangle.
Redesgn your dialog box!
David
rswy
Thanks for the tip David, but I still am not sure as to how the rectangle can be manipulated.How do I use the picture box as a container and alter the size of the rectangle I draw in it?
--rswy
