29285 Discussions
Choosing lines of code to execute when compiled in Debug but not Release
Jason_Harp
I have a program I am debugging in which I have some data written to an output file. However when I am testing to code I don't really need those extra files slowing me down. I would like to not execute those write commands when I compile in RELEASE mode, but I often forget to comment out those lines before I compile. I've seen in some C programs I work with techniques to execute certain lines of code depending on the compiler options selected.
Does any one know a way to specify a line of code so that it is only compiled when the compiler is in DEBUG mode, but it does not compile in RELEASE mode?
Les_Neilson
Valued Contributor II
In your debugproject settings Fortran->Preprocessor->Preprocessor Definitions put DEBUG
Then in your code put :
!DEC$ IF DEFINED (DEBUG)
code to execute indebug mode only
!DEC$ ELSE
!DEC$ ENDIF
Les
Les_Neilson
!DEC$ ELSE
!DEC$ ENDIF
Les
Steve_Nuchia
There is also a project properties setting, fortran / language / compile lines with "D" in column 1 / boolean
Greg_T_
In addition to the compiler directives to control active code, we also use an integer or logical flag to control debugging and log file output. I like an integer variable so that levels or amounts of debugging output can be controlled as needed. Depending on how you are running the program, you can control the integer output flag from a command line input, a value from an input file, or even a slider bar in a GUI. Since we often have a GUI written in another language like Visual Basic, it is convenient to get debugging output from the release version by using our log file. Perhaps this approach would also be helpful for you.
Greg
Steven_L_Intel1
The "D Lines" feature is for fixed-form source only. I do not recommend its use. The conditional compilation directives are the best choice.
