Code Coverage Results and Sharing
Curran_K_
I have generated code coverage results and have got the html files. I need to share these files with colleagues and there are a large number of tests that I have carried out, so it is very time consuming to email everyone/dropbox/one drive the results to everyone, which they have to copy the files over in order to click on all the file links. Does anyone recommend a better way/easier way of transferring the files?
Furthermore by using the initial results we have been able to create tests that help improve the results, is there any way that the results can be easily compared instead of having to just open two separate code coverage results?
Thanks in advance
