Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Code failure only in XE2015 and not earlier versions
HI,
REAL X(2)
N = 2
DO I=1,N+1
if( i .LE. N .and. MOD(X(i),10).EQ.2) A= A+B
ENDDO
The above code has worked fine in all past versions. But now using XE2015 it throws an exception when I=3 as it thinks the bounds of X are violated.  But it shouldn't need to evaluate the second test as the first will fail.  Is there a switch we need to set now for this to not fail?  Or do we have to rewrite all the instances of this code to be 2 IF tests?
Dave
Highlighted
Valued Contributor II
if( i .LE. N) if( MOD(X(i),10
if( i .LE. N) if( MOD(X(i),10).EQ.2) A= A+B
Fortran doesn't have short-circuiting logical operators.
Highlighted
Black Belt
R.O. has given you a concise
R.O. has given you a concise answer. In Fortran, expressions can be evaluated in any order, subject to rules regarding parentheses, etc. Therefore, your code should not be written such a way that it depends on a particular order in order to work correctly.
Observe that you are giving mixed arguments (one real, the other integer) to MOD. This should be corrected.
Your code might work (and might even work as expected) if you did not specify bounds checking, but it is not good to tolerate such unstable code.
Highlighted
ah the trouble with not
ah the trouble with not posting the real code, where X is actually an integer...
