Code not converging, help
fritoli__giovani
Hello, i'm a engineer student and never used fortran before. I'm  using it at a class, and we have to solve a 2D transient heat transfer problem. When I run my code, the solution does not converge. I think I am calculating the RMS wrong. Could you give me a hand?
gib
New Contributor II
Probably nobody will be willing to trace through your code to find your problem, and there is a general reluctance to help students with class assignments.
My advice is to learn to use debugging write statements:
write(*,'(a,i6,2e12.3)') 'This is a debugging message about: ivar, avar, bvar: ',ivar,avar,bvar
Inserting such write statements into your code should help you to find where variables are not taking the values that you expect.
fritoli__giovani
Thank you
jimdempseyatthecove
You have a tolerance (tol) that is fixed, real, at 9.0D-3
*** Note, both RMS and tol are declared (in all places) as REAL and not REAL(8) (or DOUBLE PRECISION)
You to not state the typical magnitude(s) of RMS.
REAL (single precision) floating point has 7+fraction digits of precision. Assume for the moment your tolerance is 1.0D-2. This means if your RMS is larger than 99999.nn or so, you may never converge.
I suggest you uncomment the write(*,*) residuo statements, then
a) using a data set that converges, make a run, saving the output.
b) then using a data set  that does not converge, make a run, saving the output.
then compare the two outputs. Either the RMS will never converge do to an incorrupt assumption that convergence is at 9.0E-3, or you data is corrupt and producing unusual values.
Jim Dempsey
