I am trying with quite a lot of bumps to create a project in Xcode using the intel fortran compilers. My compilation produces some object files (and the mod files as well) but breaks at a certain file. If I paste the compilation command in the terminal the compilation seems fine. The only message I get from Xcode is
Command /usr/local/bin/ifort-19.0.3.199 failed with exit code 2
the compilation command is
/usr/local/bin/ifort-19.0.3.199 -arch x86_64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.14 -g -O0 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -parallel -assume nobuffered_io -mkl=parallel -fpp -I/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Products/Debug/include -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include -I/usr/local/hdf-1-10.5/include -I/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/include -Difdef -noD -assume cc-omp -recursive -reentrancy threaded -nopad_source -altparam -nod-lines -qopenmp -standard-semantics -novms -nof77rtl -nointconstant -assume nobscc -stand f08 -warn nostderrors -warn declarations -warn unused -warn noignore-loc -warn notruncated-source -warn noalignments -warn uncalled -warn usage -warn nointerfaces -warn noshape -init=nosnan -init=nozero -align nosequence -assume nodummy_aliases -assume protect-constants -assume nobyterecl -fno-zero-initialized-in-bss -fp-model no-except -nofltconsistency -no-fp-port -no-ftz -nofpconstant -assume nominus0 -no-complex-limited-range -fp-stack-check -assume nounderscore -nogen-interfaces -module /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug -traceback -check nobounds -check nooutput-conversion -check noformat -check noarg-temp-created -check nopointers -check nouninit -check stack -check noshape -ftrapuv -u -fp-stack-check -c /Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/memory/ed_state_vars.f90 -o /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug/ED2.build/Objects-normal/x86_64/ed_state_vars.o
The file at which the compilation stops is very large (27000 lines). Apart from that it looks pretty similar to the ~10 files for which the compilation works. Also I should specify that the error is not due to the compilation order, I set it manually.
It is a very long command line - I wonder if Xcode is truncating it due to a character limit - maybe??
Can you try compiling everything up to that 1 file, then add in compiler option -dryrun to get a dump of everything passed to the compiler. Then compile just that 1 source from Xcode.
I don't think that it is truncated because if I open the command line and paste that exact line I can compile the .o and .mod files properly in the Xcode specific location.
Following your suggestion I appended a -dryrun flag in the build rules for that one file.
The dump from Xcode is:
CompileFortran /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug/ED2.build/Objects-normal/x86_64/ed_state_vars.o /Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/memory/ed_state_vars.F90 cd /Users/manfredo/Documents/Eclipse_workspace/ED2/ED2 /usr/local/bin/ifort-19.0.3.199 -arch x86_64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.14 -g -O0 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -parallel -assume nobuffered_io -mkl=parallel -fpp -I/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Products/Debug/include -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include -I/usr/local/hdf-1-10.5/include -I/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/include -Difdef -noD -assume cc-omp -recursive -reentrancy threaded -nopad_source -altparam -nod-lines -qopenmp -standard-semantics -novms -nof77rtl -nointconstant -assume nobscc -stand f08 -warn nostderrors -warn declarations -warn unused -warn noignore-loc -warn notruncated-source -warn noalignments -warn uncalled -warn usage -warn nointerfaces -warn noshape -init=nosnan -init=nozero -align nosequence -assume nodummy_aliases -assume protect-constants -assume nobyterecl -fno-zero-initialized-in-bss -fp-model no-except -nofltconsistency -no-fp-port -no-ftz -nofpconstant -assume nominus0 -no-complex-limited-range -fp-stack-check -assume nounderscore -nogen-interfaces -module /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug -traceback -check nobounds -check nooutput-conversion -check noformat -check noarg-temp-created -check nopointers -check nouninit -check stack -check noshape -ftrapuv -dryrun -c /Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/memory/ed_state_vars.F90 -o /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug/ED2.build/Objects-normal/x86_64/ed_state_vars.o /opt/intel/compilers_and_libraries_2019.3.199/mac/bin/intel64/fpp \ -D__INTEL_COMPILER=1900 \ -D__INTEL_COMPILER_UPDATE=0 \ -D__x86_64 \ -D__x86_64__ \ -D__amd64 \ -D__amd64__ \ -D__INTEL_COMPILER_BUILD_DATE=20190206 \ -D__PIC__ \ -D__APPLE__ \ -D__MACH__ \ -D_OPENMP=201611 \ -D__pentium4 \ -D__pentium4__ \ -D__tune_pentium4__ \ -D__SSE2__ \ -D__SSE2_MATH__ \ -D__SSE3__ \ -D__SSSE3__ \ -D__SSE__ \ -D__SSE_MATH__ \ -D__MMX__ \ -Difdef \ -I. \ -I/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Products/Debug/include \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include \ -I/usr/local/hdf-1-10.5/include \ -I/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/include \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include/intel64/lp64 \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/compiler/include/intel64 \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/compiler/include/icc \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/compiler/include \ -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.1/include \ -I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include/ \ -I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include \ -4Ycpp \ -4Ncvf \ -f_com=yes \ -MX \ /Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/memory/ed_state_vars.F90 \ /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199kM95n8.i90 /opt/intel/compilers_and_libraries_2019.3.199/mac/bin/intel64/fortcom \ -D__INTEL_COMPILER=1900 \ -D__INTEL_COMPILER_UPDATE=0 \ -D__x86_64 \ -D__x86_64__ \ -D__amd64 \ -D__amd64__ \ -D__INTEL_COMPILER_BUILD_DATE=20190206 \ -D__PIC__ \ -D__APPLE__ \ -D__MACH__ \ -D_OPENMP=201611 \ -D__pentium4 \ -D__pentium4__ \ -D__tune_pentium4__ \ -D__SSE2__ \ -D__SSE2_MATH__ \ -D__SSE3__ \ -D__SSSE3__ \ -D__SSE__ \ -D__SSE_MATH__ \ -D__MMX__ \ -mGLOB_pack_sort_init_list \ -I/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/memory \ -I. \ -I/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Products/Debug/include \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include \ -I/usr/local/hdf-1-10.5/include \ -I/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/include \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include/intel64/lp64 \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/compiler/include/intel64 \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/compiler/include/icc \ -I/opt/intel/compilers_and_libraries_2019.3.199/mac/compiler/include \ -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.1/include \ -I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include/ \ -I/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/usr/include \ "-align nosequence" \ -altparam \ "-assume nobuffered_io" \ "-assume cc_omp" \ "-assume recursion" \ "-assume byterecl" \ "-assume fpe_summary" \ "-assume minus0" \ "-assume noold_ldout_format" \ "-assume noold_maxminloc" \ "-assume noold_unit_star" \ "-assume noold_xor" \ "-assume protect_parens" \ "-assume realloc_lhs" \ "-assume std_intent_in" \ "-assume std_minus0_rounding" \ "-assume std_mod_proc_name" \ "-assume std_value" \ "-assume nobscc" \ "-assume nodummy_aliases" \ "-assume protect_constants" \ "-assume nobyterecl" \ "-assume nominus0" \ "-assume nounderscore" \ -automatic \ "-check nobounds" \ "-check nooutput_conversion" \ "-check noformat" \ "-check noarg_temp_created" \ "-check nopointers" \ "-check nouninitialized" \ "-check stack" \ "-check noshape" \ -fpe0 \ -noftz \ "-fpscomp logicals" \ "-fp_model no_except" \ "-fp_modspec fp_speculation_OFF" \ "-fp_modbits no_ftz" \ "-init nosnan" \ "-init nozero" \ "-init snan" \ "-module /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug" \ -omp \ -omp_simd \ -parallel \ -O0 \ -nopad_source \ -g2 \ "-reentrancy threaded" \ "-stand f08" \ -traceback \ "-warn declarations" \ "-warn unused" \ "-warn noignore_loc" \ "-warn notruncated_source" \ "-warn noalignments" \ "-warn uncalled" \ "-warn usage" \ "-warn nointerfaces" \ "-warn noshape" \ -simd \ -mGLOB_em64t=TRUE \ -mP1OPT_version=19.0-intel64 \ -mGLOB_diag_file=/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug/ED2.build/Objects-normal/x86_64/ed_state_vars.diag \ -mGLOB_diag_use_message_catalog=FALSE \ -mGLOB_long_size_64 \ -mGLOB_routine_pointer_size_64 \ -mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \ -mP2OPT_static_promotion \ -mP1OPT_print_version=FALSE \ -mCG_use_gas_got_workaround=F \ -mP2OPT_align_option_used=TRUE \ -mGLOB_gcc_version=490 \ "-mGLOB_options_string=-I/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Products/Debug/include -I/opt/intel/compilers_and_libraries_2019.3.199/mac/mkl/include -I/usr/local/hdf-1-10.5/include -I/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/include -arch x86_64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk -mmacosx-version-min=10.14 -g -O0 -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -parallel -assume nobuffered_io -mkl=parallel -fpp -Difdef -noD -assume cc-omp -recursive -reentrancy threaded -nopad_source -altparam -nod-lines -qopenmp -standard-semantics -novms -nof77rtl -nointconstant -assume nobscc -stand f08 -warn nostderrors -warn declarations -warn unused -warn noignore-loc -warn notruncated-source -warn noalignments -warn uncalled -warn usage -warn nointerfaces -warn noshape -init=nosnan -init=nozero -align nosequence -assume nodummy_aliases -assume protect-constants -assume nobyterecl -fno-zero-initialized-in-bss -fp-model no-except -nofltconsistency -no-fp-port -no-ftz -nofpconstant -assume nominus0 -no-complex-limited-range -fp-stack-check -assume nounderscore -nogen-interfaces -module /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug -traceback -check nobounds -check nooutput-conversion -check noformat -check noarg-temp-created -check nopointers -check nouninit -check stack -check noshape -ftrapuv -dryrun -c -o /Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug/ED2.build/Objects-normal/x86_64/ed_state_vars.o" \ -mGLOB_position_independent_code \ -mGLOB_preemption_model=1 \ -mGLOB_no_compact_unwind=TRUE \ -mGLOB_cxx_limited_range=FALSE \ -mGLOB_traceback \ -mCG_extend_parms=FALSE \ -mGLOB_compiler_bin_directory=/opt/intel/compilers_and_libraries_2019.3.199/mac/bin/intel64 \ -mP3OPT_emit_line_numbers \ -mP2OPT_suppress_unreferenced_locals=FALSE \ -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL \ -mDEBUG_info_level=2 \ -mP1OPT_vft_trigger_debug_types=FALSE \ -mIPOPT_ninl_debug_info=TRUE \ -mDEBUG_emit_dwarf_inline_info=TRUE \ -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF20 \ -mP3OPT_dwarf_format=P3OPT_DWARF_FORMAT_OBJ_ONLY \ -mGLOB_as_output_backup_file_name=/var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_19996YWl4as_.s \ -mP3OPT_debug_gz=10 \ -mGLOB_uarch_tuning=0x0 \ -mGLOB_product_id_code=0x22006d91 \ -mGLOB_maintain_errno \ -mGLOB_noinline_intrinsics \ -mGLOB_use_base_pointer=1 \ -mCG_fpstkchk=TRUE \ -mCG_bnl_movbe=T \ -mGLOB_fp_speculation=GLOB_FP_SPECULATION_OFF \ -mGLOB_extended_instructions=0x80 \ -mP3OPT_use_mspp_call_convention \ -mP2OPT_subs_out_of_bound=FALSE \ -mP2OPT_disam_type_based_disam=2 \ -mGLOB_ansi_alias \ -mGLOB_no_zero_initialized_in_bss \ -mIPOPT_ninl_limit=0 \ -mIPOPT_ninl_user_level=0 \ -mPGOPTI_value_profile_use=T \ -mP2OPT_align_array_to_cache_line=FALSE \ -mPAROPT_openmp=TRUE \ -mP2OPT_hpo_omp_simd_only=FALSE \ -mCG_stack_security_check=0x9 \ -mP2OPT_gen_linux_const_pooling=FALSE \ -mGLOB_opt_level=0 \ -mIPOPT_args_in_regs=0 \ -mP2OPT_disam_assume_nonstd_intent_in=FALSE \ -mGLOB_imf_mapping_library=/opt/intel/compilers_and_libraries_2019.3.199/mac/bin/intel64/libiml_attr.dylib \ -mP2OPT_hlo_embed_loopinfo \ -mPGOPTI_gen_threadsafe_level=0 \ -mIPOPT_obj_output_file_name=/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug/ED2.build/Objects-normal/x86_64/ed_state_vars.o \ -mIPOPT_whole_archive_fixup_file_name=/var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199warchKiPbCw \ -mGLOB_linker=/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld \ -mGLOB_driver_tempfile_name=/var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199tempfileXREfDv \ -mGLOB_os_target=GLOB_OS_TARGET_MACH \ -mGLOB_async_unwind_tables=TRUE \ -mGLOB_obj_output_file=/Users/manfredo/Library/Developer/Xcode/DerivedData/ED2-bzpotpyhearnjhdlpmzxdtkugvki/Build/Intermediates.noindex/ED2.build/Debug/ED2.build/Objects-normal/x86_64/ed_state_vars.o \ -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \ -mP1OPT_source_file_name=/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/memory/ed_state_vars.F90 \ -mP1OPT_full_source_file_name=/Users/manfredo/Documents/Eclipse_workspace/ED2/ED/src/memory/ed_state_vars.F90 \ -mP2OPT_symtab_type_copy=true \ /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199kM95n8.i90 rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199dashvE6xeyP rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199dummyUlNCdy.c rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199xcrunEnVgc9 rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199searchdirs8ZS3Q3 rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199clangdashvNexo7g rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199kM95n8.i90 rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199osN5bGsO rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199tosgqTU07 rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199argy9wK7o rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199os8Wqp8f rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199tosQpVuoi rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199gdb_vP9VFkW rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_19996YWl4as_.s rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199tempfileXREfDv rm /var/folders/yl/9ln6pnbs5k5_wrwqvz06t0100000gn/T/ifort-19_0_3_199argn5dvPZ
Ronald,
Manfredo stated: The file at which the compilation stops is very large (27000 lines).
It is not completely clear as to if he meant at the command line (in the script/make file) or inside the compiler once starting to compile.
The only odd think I see in the -dryrun is: line 159
"-mGLOB_options_string=-I/Users..."
I am not sure if ifort will treat this equivalent to
-mGLOB_options_string="-I/Users..."
Jim Dempsey
The file ed_state_vars.F90 is the file which fails to compile. That file is ~27000 lines.
