Comment line beginning with "C" is not shown in green in the editor.
Don_D_
Comment line beginning with "C" is not shown in green in the editor.  On an older PC, it was.  Compilation is correct in both cases.
jimdempseyatthecove
Is your file extension .F90? If so, you IDE is likely assuming the because this is a Free Format source file, the comment indicator is ! and not C in column 1.
I am assuming you are using Microsoft Visual Studio.
Jim Dempsey
Don_D_
I use fixed-format Fortran.  All of the source-code modules are type .for.  I am using VS 2010.
Here is the Command Line:
/nologo /O3 /Ob0 /Oy- /Qipo /I"Release/" /reentrancy:none /fixed /extend_source:132 /Qopenmp /Qdiag-error-limit:30000 /Qdiag-file:"Release\SYNOPSYS200_lib_.diag" /Qauto /align:rec4byte /align:commons /assume:byterecl /Qtrapuv /Qzero /fpe:1 /fp:precise /Qfp_port /fpconstant /Qftz /Qfp-stack-check /Qfp-speculation=safe /iface:cvf /module:"Release/" /object:"Release/" /Fd"Release\vc100.pdb" /traceback /check:none /libs:dll /threads /winapp /c
/nologo /debug:full /Od /heap-arrays0 /I"Debug/" /reentrancy:none /extend_source:132 /Qopenmp /Qopenmp-report1 /warn:unused /warn:truncated_source /Qauto /align:rec4byte /align:commons /assume:byterecl /Qtrapuv /Qzero /fpe:1 /fp:strict /Qfp_port /fpconstant /Qftz /Qfp-stack-check /iface:cvf /module:"Debug/" /object:"Debug/" /Fd"Debug\vc100.pdb" /traceback /check:all /libs:dll /threads /winapp /c
Steve_Lionel
The command line used is not relevant. Please show a screenshot of Visual Studio with the source opened. Also show a screenshot of Tools > Options > Intel Compilers and Tools > Visual Fortran > General.
