Compile Error: ifort.exe not found
Marcin_S_
Hello all
I know that there was a similar topic already, but it is closed and I haven't found a proper answer out there.
I have installed Microsoft Visual Studio 2015 CE. Then I installed Intel Parallel Studio XE on student's licence. I've done it both for IA-32 and Intel64. I installed basically all of its components.
VS is able to detect the compiler "somehow" - the compiler's preferences are available and its version is displayed.
However, when i try to compile anything, this error pops out.
I have checked through hard drive and I have 4 ifort compilers (2 for IA-32 and 2 for Intel64) under C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2016.1.146\windows\bin.
I've tried to reinstall it all, change settings in VS and nothing works.
Kevin_D_Intel
Are you seeing this error when running ifort under a Windows command-prompt window or when building a Fortran solution/project?
I don't if this is a factor or not, but with Visual Studio 2015, there is an additional required component, Common Tools for Visual C++ 2015, that must be installed, that is not installed by default. Please review the article, Intel® C++ and Fortran Compilers for Windows* Integration Into Microsoft Visual Studio 2015* , for details.
Kevin_D_Intel
Marcin_S_
Dear Kevin
Thank you very much, it helped!
Best Regards
Marcin
Kevin_D_Intel
You're welcome. Glad to know that helped.
No, the Performance Libraries do not include a compiler.
I'm afraid so. There is an Academic license available, but I don't know if you'd qualify. Note that the evaluation license doesn't permit you to use built applications after the evaluation period. We do offer free licenses to students and open-source developers.
