Compile problem with nested type
Bob_G_
module type_definitions
type AA
integer :: idn
type(BB),pointer :: n
end type AA
type BB
integer :: id
type(AA),pointer :: m
end type BB
end module type_definitions
subroutine findx(kk)
use type_definitions
implicit none
type(AA) :: kk
end subroutine findx
program main
implicit none
character*18 ar,md
open(1,file='../../../Data/Model.dat')
read(1,'(a18)')ar
read(1,'(a18)')md
close(1)
end program main
"fortcom: Fatal: There has been an internal compiler error (C0000005)", but it works well with"ifort -o test test.f90" in IVF prompt. I am relly confused what is the difference between the two compile methods. Thanks for any comments.
mecej4
It is quite likely that the compiler options set inside Visual Studio are different from those in effect at the command line. Please attach the build-log from Visual Studio for the failed attempt.
I agree with mecej4.  The build log will also identify the product version you are using.  I can't reproduce this in a current version, but I may not be doing it exactly as you are.
