Compiler Internal Error
cas214
When I try to compile:
ifort -nologo -debug full -O -stand f03 -warn declarations -warn unused -warn interfaces -align rec16byte -align sequence -names as_is -traceback -checkpointer -chec bounds -check uninit -threads -c Grid.f90
and I get:
FATAL ERROR : Compiler Internal Error
ifort: error #10273: Fatal Error in /opt/intel/composer_xe_2011_sp1.8.273/bin/intel64/fortcom, terminated by 0x2
make: *** [Grid] Error 2
Thanks in advance
mecej4
Please attach the source code (Grid.f90) that causes the error.
Anonymous66
Valued Contributor I
An Internal Compiler Errormeans the compiler does not know how to handle your code because of a bug in the compiler. Sinceit is ageneric error message,Ihave to see your code in order to understand what is causing the problem.
Could youpost the code for Grid.f90,so thatI canunderstand what is causingthe error? If Grid.f90 contains proprietary information, all I need is the code necessary to reproduce this bug.
Annalee
