Compiling Old Version Code
jhk1
I failed to compile a Fortran code written about 30 years ago using the Intel oneAPI Fortran compiler 2025 integrated with Visual Studio 2022.
I think that the compiling tools are too new to compile my code.
I may need an older version compiler to fit my code.
Please help me figure out a way to compile my code.
I can show my code if there is an appropriate way.
GVautier
New Contributor III
Nothing obviously odd in this code. Be sure to compile as fixed source form and it should work.
Post compilation errors if any.
andrew_4619
Old Fortran should always compile, that is a strength of Fortran. There can be illegal stuff in your code that an old compiler did not pick up. Show some errors or code.
jhk1
The old version code has been uploaded herewith.
GVautier
New Contributor III
jhk1
It works.
Your advice is deeply appreciated.
andrew_4619
compiles ok, no errors
GVautier
New Contributor III
With a second look, I found that for some lines there is a  tabulation as first character. They must be converted to 6 blanks
andrew_4619
Yes the tabs are non-standard and are best removed  but it compiles...
GVautier
New Contributor III
There always is a risk that a text editor converts the tabs to 4 blanks and therefore the code will not be able to be compiled.
jhk1
Thanks a lot for showing me a professional attitude.
