Copy DLL to output folder
Guilherme_S_
With Intel Fortran and Visual Studio, how can I tell the compiler to add an DLL to the output folder?
In others languages (C# for example), each file added to the solution has a property called "Copy to Output Directory"
(Please see attached print scree)
Is this behavior possible with Fortran?
ZlamalJakub
New Contributor III
Select Project -> Properties -> Linker -> General ->Output File
You can write your own custom build step that does the copy. I prefer to do this rather than having the linker directly write to the output directory of another project, as this can interfere with rebuilds.
