In my program I need to copy small arrays (e.g. 20 elements) many times back and forth (obviously changing values in-between), and I've found that this takes a substantial amount of the program time. To understand what is happening I made a small test program. I compile it with both ifort (18.0.1) and gfortran (7.3.0), and ifort seems to be taking significantly more time (9.3 s versus 1.8 s). Running with static arrays results in 3.8 s with ifort and 0.0s with gfortran, the latter probably figured out that I'm doing nothing... The testing was conducted by running the script given below (I'm running on a linux cluster, hence the module loading and removing (purge) commands to have equal testing conditions and loading the newest compilers.
Are there any way of improving the performance under ifort (The CPU is Intel Haswells so should be in intel's favour). Please note if some specific output information is required.
program main
implicit none
integer, parameter :: nvar=20
integer :: clock_count, clock_rate, k1
double precision, allocatable :: var_old(:), var_new(:)
!double precision :: var_old(nvar), var_new(nvar)
double precision :: time
allocate(var_old(nvar), var_new(nvar))
var_old = 1.d0
var_new = 0.d0
call system_clock ( clock_count, clock_rate)
time = real(clock_count)/real(clock_rate)
do k1=1,int(5e8)
var_new=var_old
var_old=var_new
enddo
call system_clock(clock_count, clock_rate)
time = real(clock_count)/real(clock_rate) - time
write(*,*) time
end program
module purge module load foss # Loading gnu toolchain gfortran -O3 speedtest.f90 -o speed_gfortran echo "Running speed test with gfortran:" ./speed_gfortran module purge module load intel #Loading intel toolchain ifort -O3 speedtest.f90 -o speed_ifort echo "Running speed test with ifort:" ./speed_ifort echo "Test complete"
As you note, a compiler can decide to remove the copying since you never use it. I note that ifort doesn't do so, skewing the results. You'll get better ifort results by adding -xHost , so it can use more advanced copying instructions, but your comparison is likely not valid for a real-world program.
Thank you for your reply Steve, the -xHost did improve the speed and gfortran was doing fancy stuff to avoid doing what I wanted to test it seems like. I updated the test by adding a call to a separately compiled function, resulting in 15s for gfortran and 9.1s/7.0s for ifort (without and with xHost)
New loop:
do k1=1,int(5e8)
call dummy(var_old, var_new)
var_old=var_new
enddo
New module containing dummy:
module test implicit none contains subroutine dummy(var_old, var_new) implicit none double precision, intent(inout):: var_old(:), var_new(:) var_new = var_old + 1.d0 end subroutine end module
And new test script:
module purge module load foss gfortran -O3 -c dummy.f90 gfortran -O3 -c speedtest.f90 gfortran dummy.o speedtest.o -o speed_gfortran #gfortran -O3 -g speedtest.f90 -o speed_gfortran echo "Running speed test with gfortran:" ./speed_gfortran module purge module load intel ifort -O3 -c -xHost dummy.f90 ifort -O3 -c -xHost speedtest.f90 ifort dummy.o speedtest.o -o speed_ifort #ifort -O3 -g speedtest.f90 -o speed_ifort echo "Running speed test with ifort:" ./speed_ifort echo "Test complete"
