Here is a compiler bug affecting both ifort andf ifx:
Module MyModule
implicit none
Type :: MyType
! No error if next line is commented
type(MyType) ,allocatable :: Items(:)
End Type
contains
Subroutine MySub()
type(MyType) ,allocatable :: List(:), Items(:)
allocate( List, source = [Items] )
! No error if above line replaced with:
! allocate( List, source = Items )
End Subroutine
End Module
Note that there is no compilation error if:
- the recursion in the derived-type is removed by commenting the component 'Items' or
- the array constructor is removed in the allocate statement by removing the square brackets around 'Items'.
The output using ifx is:
ifx version 2025.0.4
ifx: error #10105: /home/opt/INTEL/oneapi/compiler/2025.0/bin/compiler/xfortcom: core dumped
ifx: warning #10102: unknown signal(-1102185024)
ifx: error #10106: Fatal error in /home/opt/INTEL/oneapi/compiler/2025.0/bin/compiler/xfortcom, terminated by unknown
compilation aborted for MyModule.F90 (code 1)
and for ifort it is:
ifort version 2021.13.0
ifort: error #10105: /home/opt/INTEL/oneapi/compiler/2024.2/bin/../bin/fortcom: core dumped
ifort: warning #10102: unknown signal(412480896)
ifort: error #10106: Fatal error in /home/opt/INTEL/oneapi/compiler/2024.2/bin/../bin/fortcom, terminated by unknown
I am thinking this is a variation of a bug that has been posted a couple of times over the last few months. Search the forum....
Thanks for the feedback. I dug into the forum up to last September but could not find any similar bug. Maybe I missed it, or maybe it is older. Do you remember if this bug has been escalated to the compiler team?
